Toymods » Tech & Conversions » fuel tank efi mods
Michael P
fuel tank efi mods Fri, 12 December 2003 03:47 Go to next message
Does anyone know if you can fit the electric fuel pump from an efi AE92 tank(4AFE)into a non-efi(4AFC)AE92 tank, or do you have to replace the whole fuel tank and efi pump an one.
toyoda
Re: fuel tank efi mods Fri, 12 December 2003 04:28 Go to previous messageGo to next message
I fitted a Camry fuel pump into a AE86 Tank.
I just cut off the original piping and soldered larger bore pipes in their place to allow for the extra volume.
I used an original pipe as a return and a Charcoal cannister breather and ran a new larger pipe to the engine.
EvilJack
Sutho/Hills NSW
Re: fuel tank efi mods Fri, 12 December 2003 04:55 Go to previous messageGo to next message
you cant with the ae92, you need an efi tank aswell...but after that you can fit a 7mgte/3sgte or rx7 which will bolt in.
ra23celica
Re: fuel tank efi mods Fri, 12 December 2003 07:28 Go to previous messageGo to next message
You can cut and shut the swimmer pump arrangement into a carby car tank, but you will suffer fuel pressurisation problems, fumes in the car and pressure build-up behind the cap, if you don't copy the same venting arrangements as the EFI tank. If you can bolt in the entire set-up including filler neck, pipes etc from the EFI car to your carby machine, do that. Save yourself the aggravation and the hassle if not always the expense, in this case.
Mitch.
[Updated on: Fri, 12 December 2003 07:30]
FKN16V
NSW, East Coast
Re: fuel tank efi mods Fri, 12 December 2003 11:50 Go to previous message
I have a vn commodore fuel pump in my ae86?
Just realised your after advice , not options.
I would dare say you will need the tank, and upgraded inlet line.
Hope it all works for you.
[Updated on: Fri, 12 December 2003 11:55]
Previous Topic:brake converson for ST162?!?!?!?!?!?
Next Topic:how to tell gt model ra40 from a standard one
Current Time: Wed Nov 18 21:04:17 UTC 2026
Total time taken to generate the page: 0.0059289932250977 seconds
