Toymods » Tech & Conversions » 18RU rocker cover oil leak
Falk
18RU rocker cover oil leak Fri, 12 December 2003 07:00 Go to next message
My kid brother has an 18RU in an RA28 fastback celica, which leaks oil into the plug recesses on the rocker cover (as in "fills them to the brim with oil").
He says that the rocker cover gasket was changed a month ago, presumably an attempt to remedy this problem.
I was wondering if anyone knew of a solution to his problem?
Thanks muchly in advance.
ra23celica
Re: 18RU rocker cover oil leak Fri, 12 December 2003 07:17 Go to previous message
Its a common problem on 18R-C's when you change the rocker cover gasket. You have to check and retighten the rocker cover nuts about a week after you fit it and then check it every so often after that. The nuts work themselves loose.
Mitch.
Previous Topic:AE86 Exhaust
Next Topic:Pedal box for ke25 hydraulic conversion
Current Time: Mon Nov 23 09:18:31 UTC 2026
Total time taken to generate the page: 0.0047218799591064 seconds
