Classifieds » Miscellaneous » engines and parts
CelicaRA45
nth ringwood, Victoria
engines and parts Sat, 13 December 2003 03:43 Go to next message
have 3 18rg for sale and spare parts the 1st has forge pistons and TRD cams in it and rod bolts etc$2000 the 2nd is needing rebiuld$300 the 3rd has wade cams and forge pistons and rod bolts etc $1500
also have a 18r still siting in a ra40$50 and i have a 1ggeu as well$200 plus i have a clip on sway bar to suit ta22 up to ra40 celicas it clips to the radius rods to give you more frt sway bar$70 have 3 sets of rear springs to suit ra40 celica were made from king springs 110 lbs 145 lbs 165 lbs and are 210 mm set in ride height $100 a set
also set of new forge pistons to suit 18rg $700and set of 2tg cams which were done by wades are 137 profile 40 /70 cam $200
also to fit these engines a factory 18rg air box assembly $150
CelicaRA45
Re: engines and parts Thu, 18 December 2003 09:57 Go to previous messageGo to next message
kick not bump
blackRA28
adelaide
Re: engines and parts Sat, 20 December 2003 04:57 Go to previous messageGo to next message
Hey,
what comp. ratio are the spare 18RG forgies at the bottom of the thread?
slightly interested..
Are they standard bore size, etc.? or are they oversized custom made?
I could be looking for a set of these in the near future, hopefully after xmas..
For interests sake, What are the specs on the two worked complete 18RGs at the top of the thread? ie comp ratio, k's, cam profiles, any accessories like dizzys, carbies etc?? or just the motors themselves?
What condition is the dead RG in? any good parts salvageable or need a complete rebuild?
Thanks heaps..
Guy
CelicaRA45
Re: engines and parts Sun, 21 December 2003 11:15 Go to previous message
the pistons are new with pins looks about 11.5 to 1 and are std bore size the 2 race engines with trd cams has forgeys in both of these 1 needs a freshen up and they both have stainless valves and ported and polish heads
Previous Topic:FS: 12" subs and amp for sale 300.
Next Topic:2TG efi + mircotech + fuel pumps and surge tank (SOLD)
Current Time: Fri Oct 23 21:38:23 UTC 2026
Total time taken to generate the page: 0.0052549839019775 seconds
