Toymods » Tech & Conversions » sw20 3sgte into st184
toof
sw20 3sgte into st184 Sat, 13 December 2003 09:13 Go to next message
ive been able to source a sw20 3sgte half hut relativly cheaply,
wanting to put it into my st184 any particular hassles i should look for over putting an st185 3sgte into the 184 ?
i was also wanting to use the box from the sw20.
Classique71
Colac, Victoria
Re: sw20 3sgte into st184 Sat, 13 December 2003 09:58 Go to previous messageGo to next message
ask CeLiCa ( note upper and lower case )
hes put a group a st185 motor in his st184 coupe - and its reliable and quick as shit off a shovel Smile
He'd be the best person to ask Smile
Doctakay
Branxton
Re: sw20 3sgte into st184 Sat, 13 December 2003 10:39 Go to previous messageGo to next message
mr2 3s-ge/gte bracketry is different to celica 3s-ge/gte bracketry.
swap it over from your 5s-fe and you shouldn't run into any hassles.
-chris-
Draza
Wahroonga
Re: sw20 3sgte into st184 Sat, 13 December 2003 21:49 Go to previous messageGo to next message
well u might already know this one but the wiring plugs probably won't match so u'll have to swap the plugs with the old loom(u might want to try and get a wiring diagram for the sw20 and the st184, i've heard toyota are reluctant to give them out).
Exaust.
the linkages will need to be changed(this is what i have been told), as it is a mid-mount box to front mount box.
I don't know the differences in the sw20 and the st185 so there may be some variance between the placing of the intercooler, u might want to just front mount it.
These are just some points to expect, i don't know them all and i might be wrong. I did the st185 into an st162.
acesquall
melbourne
Re: sw20 3sgte into st184 Sun, 14 December 2003 07:07 Go to previous messageGo to next message
imho i would not strongly recomend it. ive done alot of research and an mr2 half cut swap u would run into alot of probs. mainly the wiring harness. not unless ur getting the half cut for less than $1000 and in good condition with less than 100k kms.
u can source a st185 for about $2000 and the swap can be done yourself with limited mechanical knowledge.
im planning to do my swap over the new year.
spectral
Re: sw20 3sgte into st184 Sun, 14 December 2003 11:31 Go to previous messageGo to next message
http://gtfour.supras.org.nz/3S-GTE%20Conversion.ht m
That should help you.
sideshow
Re: sw20 3sgte into st184 Sun, 14 December 2003 12:53 Go to previous message
i could do the wiring for you if u need someone to do it
i have wired many 3sgte into mr2s and into celicas
Previous Topic:TRD Coilovers for AE86
Next Topic:KE20 problems and questions
Current Time: Wed Nov 18 17:29:22 UTC 2026
Total time taken to generate the page: 0.016577005386353 seconds
