Toymods » Tech & Conversions » flat battery and thermo fan
ta2272
flat battery and thermo fan Sat, 13 December 2003 12:20 Go to next message
hey everone i have been getting a flat battery latley, my thermo fan is constantly on when up to temp i have the thermo turning on around 80 degreese is this the best operating temp for a 2tg or should i change it.
jason
Alchemist
Re: flat battery and thermo fan Sat, 13 December 2003 13:45 Go to previous messageGo to next message
I cant tell you the temp mine turns on at, but its the bottom of the operating range, as soon as it hits the 2nd bottom line it kicks in. I did have the same problem with the thermo fan cutting in when it was hot due to flat battery, this was resolved by getting the voltage regulator replaced(was only chargeing at 10.5 instead of 14v...makes huge! difference)
Re: flat battery and thermo fan Sat, 13 December 2003 13:52 Go to previous messageGo to next message
Your fan should not be running all the time; mine only kicks in for about a minute at a time and only when the car is stationary. Adjust your thermostat.
ta2272
Re: flat battery and thermo fan Mon, 15 December 2003 02:43 Go to previous messageGo to next message
yeh but if i adjust my thermostat my car will run hotter, at the moment the thremo kicks in at 80 degrees and ive seen it go to 95 degrees on a hot day.
jason
Re: flat battery and thermo fan Mon, 15 December 2003 03:09 Go to previous messageGo to next message
You'll probably find your coolant thermostat opens at greater than 80 degrees. If you set your engine fan to kick in before the thermostat opens, the fan will be on pretty much all the time.
rob_RA40
c'town, NSW
Re: flat battery and thermo fan Mon, 15 December 2003 03:42 Go to previous messageGo to next message
norbs is on the money, also note that most toyotas run at approx 82 degrees, your fan is effectivly trying to cool the engine cooler than its proper operating temp, this is probably why the fan will not turn off.
the optimum setup would be to only need the thermo fan when u are sitting in traffic, with an efficient cooling system, normal driving should keep the temp floating around 82deg. so ON at ~90 off at ~85 is not a bad setup
i kint blemember my exact fan on/of temp settings but on regular 25degree day stuck in traffic my fans only need to run for 30seconds at a time.
dingaling
tas
Re: flat battery and thermo fan Mon, 15 December 2003 07:17 Go to previous message
interesting, I've noticed my fans never come on at all. i've tested the fans, and they work with power applied to them, but they never seem to come on when the car is hot. I'd check the thermostats for them, but i can't find them, And can they be set to exact tempratures? eg turn on at 90C? someone help me here?
Previous Topic:MA61 supra, converting to a 1G-GTE?
Next Topic:MA61 engine replacement?
Current Time: Fri Oct 23 20:03:46 UTC 2026
Total time taken to generate the page: 0.0080051422119141 seconds
