Toymods » Tech & Conversions » 18r-geu performance cams (how much?)
rx793
Perth, Western Australia
18r-geu performance cams (how much?) Sat, 13 December 2003 15:27 Go to next message
Hey, im looking at getting some better cams for my 18r-geu (im running carbies atm tho) and i wantedto know about how much its going to cost and where to get them? the best place?> and what to get?
Thanx
Steve
need_boost
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 01:02 Go to previous messageGo to next message
Take them out and get them ground, much cheaper than buying new billet ones...
Wont cost more than $200-$250 each if you're getting them ground, I wouldnt expext less than $500 each for new ones and ultimately they arent suited to your engine (bought cams are made for a wide variety of engines not just yours, whereas your cam grinder will ask you all sorts of questions on your engine, and more importantly what it is you want from your engine).
jagwa
Noosa-Queensland
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 03:04 Go to previous messageGo to next message
Have you considered having your existing cams reprofiled.
I had mine done to stage two which enabled me to comfortable Rev to 8000 rpm. Gas flowing the head is also a cheap and a great way to increase performance. Remember that whatever you do you will need to rejet your carbies and clock the timing chain.
Some experts say forget all this crap just put turbo on.
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 03:37 Go to previous messageGo to next message
Yep, turbo will get you the same power for less money and without making your car a bitch to drive on the street. I know what I'd be doing!
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 04:17 Go to previous messageGo to next message
i would suggest you try to locate a 18RGU EFI manifold and start from there, including shifting fuel AND spark control to a computer...
On their own, moded cams may introduce more problems that those solved. once you've factored in carbi mods, head work, idle problems, it's starts to approach EFI territory.
but if you're dead keen on rebuilt cams, this is the local brisbane mob well known for re-working cams:
<http://www.tighecams.com.au/>
a bit far from perth, but a handy online resource.
charles.
Mr DOHC
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 04:20 Go to previous messageGo to next message
WTF is clocking a timing chain
i got quoted drive in drive out cam install for my 18RGU for $550 including new springs
and $1000 for a pair of new billet cams, NOT INSTALLED
CelicaRA45
nth ringwood, Victoria
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 04:34 Go to previous messageGo to next message
better to get your cams hard faced welded up as just a grind will reduce base circle also need lift and dont go over 300 in duration or 260 at 50 as it will make it undriveable down low ,also dont get billets unless they are cast as steel 1s and you will have to buckets chromed and thats about 60 each from memory
Mr DOHC
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 06:20 Go to previous messageGo to next message
CelicaRA45 wrote on Sun, 14 December 2003 14:34
thats the only way i'd consider doing it
rx793
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 06:23 Go to previous messageGo to next message
Orite so in simple terms? lol i mean i just learned my engine inside and out stock...and just starting to dig into performance parts etc, so bare with me plz. Just trying to figure out the best and easiest/cheapest way to up up and go Smile
Mr DOHC
Re: 18r-geu performance cams (how much?) Sun, 14 December 2003 06:35 Go to previous message
rx793 wrote on Sun, 14 December 2003 16:23
its all a matter of cash and effort
fuck all cash: zorst
bit more: cams
too much cash BOOOOOOOOOOOOOOOOOOOOOOOOOOST
Previous Topic:AE71 or KE70 for dirt/khanacross
Next Topic:Tire Time
Current Time: Wed Nov 18 15:44:40 UTC 2026
Total time taken to generate the page: 0.0053329467773438 seconds
