Toymods » Tech & Conversions » Do watercooled turbos have to be watercooled?!?
haydennz
Do watercooled turbos have to be watercooled?!? Sun, 14 December 2003 09:51 Go to next message
My car has a CT20 non-watercooled turbo on it, I am replacing it with a watercooled CT20(later version) - The car already has a Oil cooler. So what I am wondering is, can i just bolt the water cooled version up and not worry about the water lines as the car does not have them, just bolt the oil lines back up.
Car also has a Turbo timer so always idles down and doesnt coke up, I believe this is the main reason for watercooling a turbo? (i have removed the oil cooled version and doesnt appear to any real coking, just what u'd expect)
[Updated on: Sun, 14 December 2003 09:53]
Re: Do watercooled turbos have to be watercooled?!? Sun, 14 December 2003 09:58 Go to previous messageGo to next message
i would think that they designed the bearing housing to require cooling fluid and oil. anyway, heat is the enemy of turbo bearings, the more heat you can remove the longer the bearings last.
In the garret turbo in my celica, the amount of oil being fed into the bearing housing would not take away the amount of heat that the water jacket could.
...you could experiment by seeing how long it lasts without water supply? Cool
also, would be interested in selling the flange that feeds oil to/from the older (non water cooled) CT20? (i've got a CT20 but no plumbing to connect oil feed to bearing housing)
charles.
haydennz
Re: Do watercooled turbos have to be watercooled?!? Sun, 14 December 2003 10:05 Go to previous messageGo to next message
true but as far as i can the see the main bearing housing is still identical the water cooled version just has a water jacket slapped around her? ;p
Siktoy ra23
Plumpton/sydney
Re: Do watercooled turbos have to be watercooled?!? Sun, 14 December 2003 10:13 Go to previous messageGo to next message
No they don't need to be water cooled they will run just fine with out it.
Just makc sure that you don't get a heep of shit in it
haydennz
Re: Do watercooled turbos have to be watercooled?!? Sun, 14 December 2003 10:16 Go to previous messageGo to next message
think it would adversely effect outlet temps?
Re: Do watercooled turbos have to be watercooled?!? Sun, 14 December 2003 14:44 Go to previous messageGo to next message
The water cooling is there for the longevity of the turbo more than anything else; it has nothing to do with outlet temperatures, since the vast majority of the heat is generated simply by compressing the air. Basic thermodynamics.
Go ahead and run your watercooled turbo without water cooling, but you'd be wise to idle it down extra long every time you shut it off.
Having said that, a couple of T-pieces in your heater hoses and you've got water cooling sorted... not really that hard to do!
Re: Do watercooled turbos have to be watercooled?!? Mon, 15 December 2003 01:04 Go to previous messageGo to next message
Two T pieces, 1 metre of heater hose, 6 hose clamps and 30 minutes of your time - $30
versus
Reco turbo - $400
I don't even understand why the question was asked. It's not some incredible intellectual challenge.
dcleyne
Re: Do watercooled turbos have to be watercooled?!? Mon, 15 December 2003 03:07 Go to previous messageGo to next message
Can I ask a stupid question?...
This is assuming that you are hooking the turbo cooling up to the heater lines... If not, can you elaborate on how you would hook the hoses up?
Does any coolant flow through the heater hoses if the heater valve is shut? Would you have to create a bypass at the heater valve to ensure constant coolant flow?
I'm assuming different cars use different mechanisms for delivering hot coolant to the heater core, but in my TA22 I'm fairly sure that no coolant flows in the heater lines unless the valve is open.
Dan
Re: Do watercooled turbos have to be watercooled?!? Mon, 15 December 2003 04:21 Go to previous messageGo to next message
You would bypass the heater - in other words you'd plumb it in parallel.
If for some bizarre reason this was impossible, then you could T piece the radiator hoses or even tap in some fittings.
Fattony
Re: Do watercooled turbos have to be watercooled?!? Mon, 15 December 2003 09:04 Go to previous message
dcleyne, you will find that when the water is running through the turbo it would make no diff if the heater vavlve was shut or not unlesss you plumbed it in after the heater valve which i would imagine being difficult and probably down right silly to.
[Updated on: Mon, 15 December 2003 09:05]
Previous Topic:twin turbo 18RGEU
Next Topic:coefficent drag of the ae86 trueno and levin
Current Time: Wed Nov 18 14:50:55 UTC 2026
Total time taken to generate the page: 0.005950927734375 seconds
