Toymods » Tech & Conversions » what size fuse?
Chris Davey
sunny coast, qld
what size fuse? Mon, 15 December 2003 04:48 Go to next message
for a thermo fan switch and a wiper motor switch?
I was thinking 20 amp?
[Updated on: Mon, 15 December 2003 05:05]
Re: what size fuse? Mon, 15 December 2003 06:45 Go to previous messageGo to next message
You mean a thermo fan and wiper motor running off the same circuit? If so you might get away with a 30amp.
Chris Davey
sunny coast, qld
Re: what size fuse? Mon, 15 December 2003 06:56 Go to previous messageGo to next message
no sorry, i meant two seperate fuses Smile
Re: what size fuse? Mon, 15 December 2003 08:05 Go to previous messageGo to next message
A 20amp might be fine for the thermo depending on the type of fan it is Rolling Eyes
Re: what size fuse? Mon, 15 December 2003 09:44 Go to previous messageGo to next message
don't skimp on the thermo fan switch - they pull a lot of current - so get a heavy duty fuse holder.
Chris Davey
sunny coast, qld
Re: what size fuse? Mon, 15 December 2003 23:13 Go to previous messageGo to next message
it is a 14" davies Craig one. So do you think a 40amp fuse for that one and a 20 amp for the wipers?
Re: what size fuse? Mon, 15 December 2003 23:58 Go to previous messageGo to next message
Your fan should have the current requirements printed somewhere. If it draws 20A, use a 25A fuse for a bit of headroom.
gabe
Re: what size fuse? Tue, 16 December 2003 00:58 Go to previous messageGo to next message
Norbie wrote on Tue, 16 December 2003 07:58
Its also worth mentioning that your average fuse blows at an average of 1.8 times the rated current. Therefore a 25amp fuse will blow at around 45 amps.
I believe circuit breakers are a lot more accurate....
Chris Davey
sunny coast, qld
Re: what size fuse? Tue, 16 December 2003 01:10 Go to previous messageGo to next message
thanks people. i will check somehow. (don't have box anymore) Smile
Re: what size fuse? Tue, 16 December 2003 05:07 Go to previous messageGo to next message
email davies craig and ask them what size fuse they recommend for that fan... fans also pull more current when they are starting up...
if in doubt, ask the manufacturer Wink
speakafreaka
Re: what size fuse? Tue, 16 December 2003 11:58 Go to previous message
for some reason when they were wiring up my car they put the DC thermos on the same fuse as the ECU. 20Amps, it started blowing constantly so i have it wired directly to the battery. for the fans i wouldnt recommend anything less than 25A
Previous Topic:18RG into KE20
Next Topic:Clutch question
Current Time: Wed Nov 18 20:21:59 UTC 2026
Total time taken to generate the page: 0.0080950260162354 seconds
