Toymods » Tech & Conversions » 18rgeu eqiup. compatibility questions
Steve M
18rgeu eqiup. compatibility questions Mon, 15 December 2003 06:32 Go to next message
Ok, I got the runners, plenum, main injectors and that stuff.
I was wondering if anyone knew of anything I could do about these.
I need:
fuel pressure regulator
cold start injector
throttle body and TPS
I already have the ECU and AFM thing sorted out (22re or 2SE)
Does anyone know of any of the above list that can be sourced from easier to find engines than the 18rgeu? Particularly if any of it can be used from the 2SE or 22R-E. (I know that the 22RE FPR can't be used)
Mr DOHC
Re: 18rgeu eqiup. compatibility questions Mon, 15 December 2003 10:22 Go to previous messageGo to next message
thermostat housing
all 18RG only, except for modding the shit
what is that engine in your avatar
Steve M
Re: 18rgeu eqiup. compatibility questions Mon, 15 December 2003 10:45 Go to previous messageGo to next message
Yeah, I've got the thermostat housing and the sensers.
I've heared that a 22R-E TB could be used and an external FPR from an EFi mercedes could be used but just wanted to hear if anyone knew otherwise or of better options.
The engine in the avatar is an 18rg/u/eu
It has many different generations making it up.
It looks much better from the top but I couldn't find that photo.
Re: 18rgeu eqiup. compatibility questions Mon, 15 December 2003 21:16 Go to previous messageGo to next message
personally i wouldnt really bother with the Cold start injector. Its completely disabled on my 100kw 4a-ge and the bastard starts fine.
I thought perhaps to blank it with a piece of aluminium, but was short on time.
roger
Re: 18rgeu eqiup. compatibility questions Mon, 15 December 2003 21:59 Go to previous messageGo to next message
It would supprise me if a 22re cold start injector didn't fit? also any fuel pressure regulator will work you just need to find one that will mount in place. Again check the 22re and the 2se.
Re: 18rgeu eqiup. compatibility questions Mon, 15 December 2003 22:53 Go to previous messageGo to next message
Yeah I completely removed the cold start injector on my 18R-GEU and I don't have any problems starting it. Smile
Steve M
Re: 18rgeu eqiup. compatibility questions Tue, 16 December 2003 13:14 Go to previous messageGo to next message
Excellent, thanks guys for the FPR and cold start info.
So a 22R-E TB and TPS should be ok then?
Can anyone suggest anything that would do the job better, or wouldn't there be much improvement to be made from different models?
Steve M
Re: 18rgeu eqiup. compatibility questions Thu, 18 December 2003 03:22 Go to previous messageGo to next message
well, for those who are interested
I found a TB that bots straight on, the one from a MX73 cressida, YAY!
I plan to use the FPR from a 3SFE and mount it externally, it shouldn't be too hard to do.
I couldn 't find anything to replace the cold start so I probably won't, I would have to modify the plenum to mount anythings else in there, not real keen on that.
also planning to use an old cressida or camry external EFI pump.
Thanks to those who offered ideas.
Steve M
Re: 18rgeu eqiup. compatibility questions Fri, 19 December 2003 12:33 Go to previous message
Just found out that I will have to use a 22R-E throttle body as the TPS from the MX73 TB is not compatible with the 22R-E loom, bugger, the cressida one was 4mm bigger.
The cressida fuel pump pushes 6-7 psi so hopefully that should do the job.
Previous Topic:4agze engine swap
Next Topic:Speedo drive gears
Current Time: Wed Nov 18 13:46:36 UTC 2026
Total time taken to generate the page: 0.0072340965270996 seconds
