Toymods » Tech & Conversions » AE86 carb to efi fuel tank mods
Flogbag
Sydney (Campbelltown...!)
AE86 carb to efi fuel tank mods Mon, 15 December 2003 08:03 Go to next message
Hi guys,
Planing my 4AC to either 4AGE or 4AGZE conversion and just wanted to know of those of u who have done this wat did you do in the way of fuel tank and fuel pumps....???
I live in sydney and will more than likely not have a EFI AE86 tank avaliable wat would be the best way to modify mine and add the pump?
shindeokure
melbourne
Re: AE86 carb to efi fuel tank mods Mon, 15 December 2003 09:57 Go to previous messageGo to next message
facet pump feeding a surge tank which feeds a bosch pump.. all in the engine bay, using standard fuel lines.
to me, that was the easiest option.. but you may just want to run new lines and 1 pump.
EVOSTi
cambo
      no
Re: AE86 carb to efi fuel tank mods Mon, 15 December 2003 10:07 Go to previous messageGo to next message
i just run one pump using standard lines on a boosted GZE. dont let anyone tell you the standard fuel lines arent enough, but obviously bigger lines, two pumps and a surge tank are ideal.
FKN16V
NSW, East Coast
Re: AE86 carb to efi fuel tank mods Mon, 15 December 2003 13:23 Go to previous messageGo to next message
Two fuel pumps, surge tanks, new feul lines.
What a load of crap?
I dont mean to piss on peoples feet, im sure the above mentioned systems work but think of the cost.
Fuel pump/pumps $100-500 (new or sec hand, which ever you choose)
Fuel line $20 ( not really needed but ha while your there right.
Surge tank $100
+ other little things like rubber hoses, clamps and so forth.
Get yourself a vn commodore fuel tank with pump and baffles, go to metal fabrication place (preference is up to you,or ill recommend someone) and get them to install vn baffle and pump into sprinter tank. I did and i dont regret it,
$300-350 later bang your all done
this my personnal opinion from what has been done to my car (4age ae86), i in no way mean that this setup is better, easier, safer then others that may be mentioned.
Sorry to piss on ya foot if i have, i just dont believe in surge tanks.
Steve
Henn
Rosanna, Melb
Re: AE86 carb to efi fuel tank mods Mon, 15 December 2003 13:31 Go to previous messageGo to next message
I did the Surge tank and two pumps tucked under the rear end. It works fine but was a pain in the arse to fit.
Modify the stock tank if you can as FKN16V says. Or to get started you could just run a high pressure pump straight out of the tank. It is a bit dodgy, esp. when the tank is getting empty, but I know a couple of guys who run it like that and their cars still work.
Hen
mrsoopra
Re: AE86 carb to efi fuel tank mods Mon, 15 December 2003 23:14 Go to previous messageGo to next message
I'm only using the one pump without a surge tank (4AGE).. only time i have a problem is under 1/4 tank going around corners.. The internal pump + baffle would be a good idea...
Gaz
shindeokure
melbourne
Re: AE86 carb to efi fuel tank mods Tue, 16 December 2003 06:50 Go to previous messageGo to next message
i got very good prices on my setup so it was worth it:
facet pump from a mazda 626 - $55
alloy surge tank - $110
bosch 220L pump - $150 (new)
hoses/clamps/fittings - about $30
hardest part was screwing in the clamps in awkward positions.
frank_grimes
Re: AE86 carb to efi fuel tank mods Tue, 16 December 2003 12:43 Go to previous messageGo to next message
i ran my 4age with no surge tank, like (mrsoopra) said as long as it was over 1/4 off tank I had no problems..
Since the 4age's been ditched in favour of gze power a surge tank and another fuel pump was added.
In short if your pick is 4age buy a smaller fuel pump first as you can use it as a lift pump later.
MY 2 cents
Cool
Bazooka
Gold Coast
Re: AE86 carb to efi fuel tank mods Tue, 16 December 2003 12:48 Go to previous message
I ran 2 pumps and a surge tank until one of my pumps packed up. Started using the single pump to get me out of trouble and never went back to the other setup. Have no real problems at low fuel levels even though its in a Suzuki Sierra that goes offroad so gets on all sorts of steep angles.
Previous Topic:MA70, 1UZ-FE AFM, stock injectors, bosch 040 fuel pump custom AFPR
Next Topic:18RG into KE20
Current Time: Wed Nov 18 21:04:11 UTC 2026
Total time taken to generate the page: 0.016678094863892 seconds
