Toymods » Tech & Conversions » new motor in ta22, few probs
Alex_B
Caboolture QLD
new motor in ta22, few probs Mon, 15 December 2003 20:42 Go to next message
new motor is a 2T old motor was a 1980ish 3T from a T-18.
i had to use my own fuel pump, (wasn't supplied, should be able to get the orignal one i hope) when you go for a drive you get through first second third forth then she runs out of fuel, and you have to pull over (sometime it will do it in 3rd). when it does this if you push the clutch in whilst moving the egine will stall. is this a pump problem? and you can't get to 100km/h because of this but you can cruise around at 60 ok. and i keep blowing the heater core fuse ??? which cuts out the dash? has never done that before, any idea's guys?
have tried blocking off the return line which it seemed to get me to forth gear instead of third before i'm empty (but may have been lucky)
also what is the triangular shaped canister thing which bolts onto the block beside the oil filer, it has a gasket. and has a outlet hose? it is blocked off at the moment, should it go somewhere? (old motor (3T) didn't have one)
Ta
Alex
Ps. i've lost my engine book hence all the question's Confused
[Updated on: Mon, 15 December 2003 20:44]
bman
melbourne
Re: new motor in ta22, few probs Mon, 15 December 2003 20:53 Go to previous messageGo to next message
hey, had a similar problem with my 3T fuel pump, at first it was intermittent, supply starving at higher rpm, felt like it could not keep fuel up to the weber, ultimately it then gave out completely. i would invest in a electric fuel pump.
roger
Re: new motor in ta22, few probs Mon, 15 December 2003 23:43 Go to previous messageGo to next message
do you have the return and inlet lines around the right way?
Alex_B
Caboolture QLD
Re: new motor in ta22, few probs Tue, 30 December 2003 21:34 Go to previous message
hohoho the intake and return line were around the wrong way Laughing (after buying a elec fuel pump, d'oh) , but still wouldn't idle, found after rebuilding the carb it has a solinoid on it which my old engine did not, aparently when you don't hook this up the fuel is shutoff for the idle port Very Happy goes sweet as now, except for a metallic rattle @ 3rd or 4th piston, checked clearences (tappets) all good, any ideas? noise coming from the head area,
Ta
does anyone need a $130 repco fuel pump?good for up to 3l engines, it's an all polymer one $100 ono
Previous Topic:Quick read: Intake flow restriction caused by bends
Next Topic:sanding heat cure paints back?
Current Time: Sat Nov 21 02:28:39 UTC 2026
Total time taken to generate the page: 0.0053031444549561 seconds
