Toymods » Tech & Conversions » AWD Dyno VS. RWD Dyno
Stephen2
Melbourne, VIC
AWD Dyno VS. RWD Dyno Tue, 16 December 2003 04:53 Go to next message
My friend has had his car dyno'ed at 116kw on an AWD dyno.
He wants to know about conversion to power at the rear wheels.
Is it a strict divide by 2 formula, or are there other factors involved?
ehendrikd
ballarat
Re: AWD Dyno VS. RWD Dyno Tue, 16 December 2003 04:57 Go to previous messageGo to next message
i'm not to informed about this sort of thing, and i'm sure someone will give a more accurate reponce, but here goes:
don't the awd gearboxes have differing distrubution to the front and rear? i have heard that the awd skylines are something like 60% rear and 40% front. so to determine if you can divide by 2 depends on the car
Classique71
Colac, Victoria
Re: AWD Dyno VS. RWD Dyno Tue, 16 December 2003 11:06 Go to previous messageGo to next message
what type of car was it first ?
On an AWD dyno my gt4 pulled 113kw at all wheels with a 50:50 split
So if its lesser than a gt4 - id say its only recording the rear wheel figure only ..
Im pretty sure dyno dynamics ones have different load modes for FWD AWD and RWD ..
your mates car wouldnt be spinning the front rollers, just the back ones
Stephen2
Melbourne, VIC
Re: AWD Dyno VS. RWD Dyno Tue, 16 December 2003 20:55 Go to previous messageGo to next message
It's an Audi TT, w/ K4 turbo and motec management system.
430 Nm torque out of a 1.8 litre engine!!
I LOOOOVE it..
He just wants to know the exact power figure at the rear wheels.
Maybe it's just double 116kw because the front rollers aren't spinning at all.. Would make it 232rwkw which is about right.
It's a BRUTE car, that one..
Ribbo
Northern Beaches
Re: AWD Dyno VS. RWD Dyno Tue, 16 December 2003 21:16 Go to previous messageGo to next message
umm I think you will find that just because its an 4wd dyno doesn't mean it measuring like that, id say it has setting to make it just meansure rear wheels and it would just be like a normal rwd dyno?
E30-323ti
Re: AWD Dyno VS. RWD Dyno Tue, 16 December 2003 22:24 Go to previous messageGo to next message
I presume this Audi TT is 4wd??
If so, is there some way of getting it to run in Rwd only??
If there isn't I would be very concerned about the state to the centre diff. If it is a clutch type LSD centre this would add load to the engine that the dyno rollers aren't seeing/measuring, not to mention completely F&*king the diff and reducing the measured power output.
I imagine in this scenario the car would be really hard to keep on the rollers as the front wheels will be trying to drive off and the front rollers must have been locked.
I don't know if a torsen (mechanical) LSD would even let the rears spin with out the fronts turning also, and an open centre would spins the rears without the fronts turning, but it would be very hard on the spider gears.
pro_ke
adelaide
Re: AWD Dyno VS. RWD Dyno Tue, 16 December 2003 23:51 Go to previous messageGo to next message
you would get a better reading off one of those dynos where you actually take the wheels off and bolt the sensors up to the hubs, i think PAC in sydney use this type (their cars broke a few 'roller' dynos apparently)
does your mate really need to know the exact amount of power its making? a dyno is a tuning tool first, a measuring device last... its not there to determine how much power you are making
ab
Stephen2
Melbourne, VIC
Re: AWD Dyno VS. RWD Dyno Tue, 16 December 2003 23:56 Go to previous messageGo to next message
Haha, yeah, I know.. But he's keen to know exact figures on his new toy Smile
It's a RWD.
Thanks anyway, guys.
Joshstix
Toymods Vice President
Re: AWD Dyno VS. RWD Dyno Wed, 17 December 2003 01:11 Go to previous messageGo to next message
If the car is a rear wheel drive and it was dynoed correctly even if the dyno is a AWD dyno then the result is how much power it was putting down to the rear wheels. Four wheel drive dyno's are simply 2 2WD dyno's put next to each other, when running a 2WD car it is exactly the same as just having a 2WD dyno.
Classique71
Colac, Victoria
Re: AWD Dyno VS. RWD Dyno Wed, 17 December 2003 01:50 Go to previous messageGo to next message
thats what i thought Josh ..
116kw at the rears..
Hmm - i looked at the figures for a stock early TT - and its figures are similar - if not less than the GT4 if i remember rightly..
id assume a worked one would put out a lot more power than a Gt4 like mine though, especially if its only driving 2 instead of 4 wheels
Ok - here are the current 2004 Audi TT power figures for stock 4wd and Front wheel drive
All wheel drive version - 225hp ( flywheel ) 207 ft lb's torque .
Front wheel drive version - 180 Hp (flywheel ) 173 ft lbs torque
Figures quoted off edmunds )
GT4 like mine - in stock form ( 1990 St185 )
222hp ( flywheel ) 202 Lb ft torque..
Seeing mine puts out more power in its modified state than a current AWD turbo Audi TT - im guessing one of 2 things ..
The dyno isnt reading correctly ( ie operator didnt set it up right ) Or your mates TT isnt as powerful as he thinks ( though that torque figure you gave would disagree ..
Somethings fishy here - im not sainting your friends pulling your leg - but the figures dont add up for what weve been shown - ahgainst a car with similar power outputs as example ..
Are you sure its not All wheel drive ? then 116 odd KW would sound a little more correct ?
Stephen2
Melbourne, VIC
Re: AWD Dyno VS. RWD Dyno Wed, 17 December 2003 02:30 Go to previous messageGo to next message
I'm positive his figures are accurate, but his terminology may be wrong in terms of what kind of dyno the testing was done on.
Regardless of the exact power output, the thing is a dream. Comfort, style and POWER to burn.
Plus for some reason even the Motec tuner doesn't understand, the boost kicks in SUPER quick. It's making 14 psi at 2500rpm!!
Madness..
He's been advised that the setup is perfect, as you could get more top end power with a t66 but the engine strength might start to be an issue.
What a beast. My Cressy will go as hard, though, once I've finished with it!
Re: AWD Dyno VS. RWD Dyno Wed, 17 December 2003 02:43 Go to previous messageGo to next message
Stephen2 wrote on Wed, 17 December 2003 07:55
I LOOOOVE it..
1.8L = 430Nm = about 20Psi?? (1.4bar)?? is that close to what he's running?
what rpm is the peak torque and power at?? some simple maths will tell you what you should be after....
fwiw, i know of a few audis (5000 quattros??) that have torque between 400 and 500Nm.... nasty little suckers they are!! (oh, and MS'd Wink )
Stephen2
Melbourne, VIC
Re: AWD Dyno VS. RWD Dyno Wed, 17 December 2003 02:47 Go to previous messageGo to next message
It's running a max 1.8bar, after some re-tuning from the Motec specialist.
The original mechanic just was NOT up to the job. Called in the big guys, and gained an extra 10% torque/power output, while sorting out idle problems and smoothness.
I'd love to be in that thing accelerating all the way to top speed...
AudiS3
Re: AWD Dyno VS. RWD Dyno Sat, 06 November 2004 13:18 Go to previous message
Just thought I would clarify this.
The Audi TT and Audi S3 are basically the same car....besides the shape. They run a Haldex 4WD system. Basically until the Front wheels slip the rear wheels do nothing. With an APR chip the boost goes to 22 PSI. (Noone ever believes this). Mine is throwing out 360NM at 2200RPM at the flywheel and just under 200kw. About 145kw at the wheels. Basically it is a front wheel drive until required. Launching these is tricky as you can imagine. The VW R32 is the same.
[Updated on: Sat, 06 November 2004 13:21]
Previous Topic:Extractors on 3t - worthwhile?
Next Topic:ST141 Digital Dash...
Current Time: Thu Nov 19 16:00:14 UTC 2026
Total time taken to generate the page: 0.070245981216431 seconds
