Toymods » Tech & Conversions » JZA70 digital dash into MA70.
NFN_UKSupra
United Kingdom
JZA70 digital dash into MA70. Tue, 30 July 2002 00:45 Go to next message
Hi All
I am a new member. I live in the UK and own two Supras. And I need a bit of help.
One is stock MA70 (UK Spec) 3.0i normally aspirated, in perfect order.
The other is a non running J1Z GTE (JZA70) 3.0i turbo Jap import.
I think the ECU is blown and it has the infamous 7MGE/GTE blown head gasket. I'm trying to locate an ECU presently and price up the the head gasket repair (inlcuding any head/block machining that may be needed). I would like to restore the JZA70 to working order, but if I can't I'll strip it for all usable spares for my MA70.
I also have a digital dash from a JZA70 (The JZA70 I have is fitted with the analogue dash). If I can get the JZA70 running I would like to install the digital dash into it. If not the JZA70 into the MA70 (The later probably being the most likely outcome).
Has anyone done this to a Supra? If so were wiring diagrams showing the digital dash connections used? Or does anyone know where I can get the wiring diagrams (all off) for a JZA70?
If anyone can help. It would be very much appreciated.
Many thanks in advance
Neil
HedgehogSandwich
UK
Re: JZA70 digital dash into MA70. Tue, 30 July 2002 09:38 Go to previous message
hmmm,, you're confusing everyone here.
The JZA70 only ever comes with a 2.5 twin turbo, not a 3.0 turbo as you say you have. If you have indeed got a JZA70 with a 3.0 in it then its a transplant, probably because of a blown original 2.5 engine, although this seems unlikely. Are you sure its a JZA and not an MA 3.0 GT? (these normally have similar to jap spec compared to our UK versions). Check you VIN and log book *and have a look at the engine !!!!) and let us know what you've actually got.
As for the digidash transplant, its a lot of work...stick with the dials.
adi
PS if you're in the UK i presume you've joined UK supras ? (and dont forget the new mkiii bbs below)
[Updated on: Tue, 30 July 2002 12:47]
Previous Topic:Hey who's got the 1JZ-GTE wiring diag again???
Next Topic:Turboing A 4age 100kw...please help....
Current Time: Sat Oct 31 13:22:15 UTC 2026
Total time taken to generate the page: 0.003593921661377 seconds
