Toymods » Tech & Conversions » Goodridge (from USA) Steel Braided Brake Lines
hiaaa
Goodridge (from USA) Steel Braided Brake Lines Tue, 16 December 2003 11:12 Go to next message
Are they street legal in Australia? Thanks!
Leon
Re: Goodridge (from USA) Steel Braided Brake Lines Tue, 16 December 2003 11:32 Go to previous messageGo to next message
afaik they are not legal in NSW. mostly because brake lines are specifically covered by ADR's, and also becuase with steel braided brake lines, you can't see if the rubber underneath is damaged.
just having steel braid on the outside is of little use except stopping damage from occasional contact. properly made ones can help, but the difference is sfa on a road car...
check with an engineer as to whether they contravene either ADR's or your states rego laws.
shinybluesteel
melbourne
Re: Goodridge (from USA) Steel Braided Brake Lines Tue, 16 December 2003 23:09 Go to previous messageGo to next message
ADR approved braided brake lines have a rubber "bit" cast around where the brake line enters the banjo bolt or whatever, to pass the test they must be able to be "cracked like a whip" without the fitting at the end coming off, apparently. im sure they would have a more sophisticated test for this too.
Re: Goodridge (from USA) Steel Braided Brake Lines Tue, 16 December 2003 23:37 Go to previous messageGo to next message
hiaaa wrote on Tue, 16 December 2003 22:12
Leon
you need to have a look at a copy of ADR 7, possibly ADR 31
see if they apply to your vehicle (some are retrospective for mods), and then if the brake lines pass.
Cya, Stewart.
Quote:
ADR 7 - Hydraulic Brake Hoses
The function of this Australian Design Rule is to specify the performance requirements of hydraulic brake hoses in vehicles so that the risk of failure in service will be minimised.
ADR 31 - Hydraulic Brake Systems for Passenger cars
The function of this national standard is to ensure safe braking under normal and emergency conditions for vehicles equipped with hydraulic service brakes.
hiaaa
Re: Goodridge (from USA) Steel Braided Brake Lines Wed, 17 December 2003 10:34 Go to previous messageGo to next message
Thanks guy, I may just get some rubber one then.
Leon
wraith
Albany WA
Re: Goodridge (from USA) Steel Braided Brake Lines Fri, 19 December 2003 01:02 Go to previous messageGo to next message
High Performance Imports magazine, issue 31. Martin Donnan's Soarer was fitted with braided brake lines made by Steve Malkins. These have been ADR approved & come with paperwork to prove it. (Maltech: 0418 378 937). Braided lines are used instead of rubber because they don't expand under pressure, giving you more "feel" from the pedal and probably superior braking. I have no idea as to the factuallity of this article, but it makes sense to me.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Goodridge (from USA) Steel Braided Brake Lines Fri, 19 December 2003 02:22 Go to previous messageGo to next message
One of our forum sponsors, Pittwater Clutch & Brake, manufacture ADR compliant braided brake lines. They even supply you with a certificate to prove there compliance.
wraith
Albany WA
Re: Goodridge (from USA) Steel Braided Brake Lines Fri, 19 December 2003 02:26 Go to previous messageGo to next message
So there you have it. No more problems with those nasty people down at the RTA.
Re: Goodridge (from USA) Steel Braided Brake Lines Fri, 19 December 2003 08:59 Go to previous messageGo to next message
coool, good to hear!!!!
it's funny that with aircraft, it is the other way round.. you have to use braided (at least thats what my Qantas friend tells me..)
must be a bit of an issue if they provide certification for them tho...
heh heh, you get pulled over and haul out your 50 page modifications 'manual' LOL Laughing
hmm, i wonder how much more feel you get.. i wouldn't expect normal brake lines to expand that much, or that there is enogh pre-stress in the braided ones to allow them to prevent them from expanding..
anyone got first hand experience?
BigWorm
Turramurra, Sydney.
Re: Goodridge (from USA) Steel Braided Brake Lines Fri, 19 December 2003 13:57 Go to previous message
Even the braided hose they use at Qantas is no good for brake lines.
I'm pretty sure the main difference is that normal braided hose for use in aircraft or whatever, is only subjected to occasional & very minimal flex, whereas flexible brake lines are subject to constant flexing. I've heard stories about guys at work (Qantas) having braided brake lines made up & they've completely shagged out in around 3 months. The most experienced hose & tube guy at Qantas refuses to make them, but will usually make up anything else people might need. Smile
Previous Topic:Info on 1979-83 2wd single cab RN Hilux
Next Topic:4agze engine swap
Current Time: Fri Oct 23 21:39:56 UTC 2026
Total time taken to generate the page: 0.0051097869873047 seconds
