Toymods » Tech & Conversions » Problems with 7mgte soarer 3.0 GT 88
ChaserJZX100
melbourne
      wtf is a jabber handle
Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 07:30 Go to next message
Well its not my car but a mates and he just wanted to post up a few things, we found oil in the spark plug hole like 1-2cm deep what has caused that? and all so take offs are shakey, over heats real fast, and he also thinks its miss firering. Anyone know the causes for this? any replie would be great thanks guys...looking in your direction allan
Nate
Soarer
Wollongong
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 07:41 Go to previous messageGo to next message
7M-GTE... blown head gasket ?
sideshow
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 07:50 Go to previous messageGo to next message
i have come across a camry with leaking seals round the rocker cover around where the spark plugs go into
just check that the oil hasnt run down from the rocker cover
the oil will eventually weep thru the spark plug thread and oil up or foul the spark plug and then the engine will miss
check this b4 u start looking for blown headgasket
ChaserJZX100
melbourne
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 08:20 Go to previous messageGo to next message
Thanks guys thats what i orginally thought, i'll relay the info back and see what happens...
Nate
dingaling
tas
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 08:32 Go to previous messageGo to next message
I had the same exact problem with my supra 7mgte, one day after flooring it, it suddenly was running on 5 cylinders.
Later on found alot of oil in the spark plug well.
replaced the cam cover seals, put new spark plugs in, and tightened the cam covers down real good.
haven't had a problem since.
[Updated on: Wed, 17 December 2003 08:42]
ChaserJZX100
melbourne
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 08:35 Go to previous messageGo to next message
now thats some straight out info lol, did you know what caused the problem?
Nate
dingaling
tas
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 08:46 Go to previous messageGo to next message
yeah, a combination of old hardened/cracked rubber cam seals, and loose screws that hold the cam covers down.
ChaserJZX100
melbourne
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 08:49 Go to previous messageGo to next message
thanks man
Nate
Danners
Central Coast, NSW
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 21:38 Go to previous messageGo to next message
Blown head gasket... nearly for sure Smiley = the misfiring/overheating gives it away
Dan
SUPRAGTE
North Sydney
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 22:24 Go to previous messageGo to next message
It'll be the oil, earthing out the plug which inturn takes out two cylinders cause 7mgte's run twin coil packs and the misfiring of two cylinders and incorrect burning of the fuel cause it's dieseling will cause massive combustion temps and the overheating your seeing.
ChaserJZX100
melbourne
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 23:01 Go to previous messageGo to next message
Now apparently theres alot of white smoke at idle! when you rev more comes out, the exhaust i mean.
Nate
Re: Problems with 7mgte soarer 3.0 GT 88 Wed, 17 December 2003 23:51 Go to previous messageGo to next message
White smoke = water = BHG. Sad
SIMDOG
Bayside Melbourne.
Re: Problems with 7mgte soarer 3.0 GT 88 Thu, 18 December 2003 02:04 Go to previous messageGo to next message
I had the rocker covers leaking oil into the spark plug area on my 7MGE... It's a bastard to get the oil out of there once you replace the rocker cover gasket. I just pulled the plugs and it drained into the cylinders (didn't know what else to do)... The car blew clouds of smoke for 45 min once I got it started. Shocked
rvrolla
Central Coast
Re: Problems with 7mgte soarer 3.0 GT 88 Thu, 18 December 2003 03:09 Go to previous message
When i got my BHG fixed we replaced the black metal strip thingy? Razz down between each cam cover. Thart stopped all the oil build up in the spark plug holes.
Previous Topic:which tranny fits the 2tg and 18rg
Next Topic:1g boost
Current Time: Sun Oct 25 15:45:43 UTC 2026
Total time taken to generate the page: 0.051862001419067 seconds
