Toymods » Tech & Conversions » 18rg oil-whats everyone using?
Jason
18rg oil-whats everyone using? Wed, 17 December 2003 10:19 Go to next message
Im just about finished a slight rebuild on a 18rg (didnt replace bearings but most everything else).
Whats everyone using for engine oil i was thinking about using GTX2 because thats what i have always used in the rc.
M.J.H
Re: 18rg oil-whats everyone using? Wed, 17 December 2003 10:30 Go to previous messageGo to next message
I tried the GTX but have since used Penzoil 50 grade since.
Doesn't matter what oil i use the preesure goes down to zero at idle after a couple of hard runs.
Sad
Time for an oil pump mod i think.
Malicia
Re: 18rg oil-whats everyone using? Wed, 17 December 2003 11:14 Go to previous messageGo to next message
I used that Castrol Magnatec?? in my rc and it loved it maybe give it ago.
Jason
Re: 18rg oil-whats everyone using? Wed, 17 December 2003 21:33 Go to previous messageGo to next message
mjh i have spare used pumps if your intrested.
Anyone else????
CLG
Perth, Western Australia
Re: 18rg oil-whats everyone using? Thu, 18 December 2003 04:49 Go to previous messageGo to next message
I'm not so much interested in the type of oil used, but more the regularity with which it is changed. I change the oil every 5000Kms in my daily driver, and due to this fact I only use Shell Helix 20w50 ($14 for 5 litres so it's a good economical alternative). while some of you may say, this is basic oil and not worth using, the fact remains it is still brewed to an Australian standard as are all other oils in the market place.
The fact it is changed twice as regularly as normal service intervals, helps to keep the engine free of contaminants, and protects the bearings better. I'm sure we've all pulled a motor apart that has missed oil changes to find the bearings and adjoining surfaces scored with carbon deposits.
In my Celica with 3TGTE, I'm currently using Penrite HPR Turbo (think they call it HPR 40 now?), and this is changed more often, as it works harder than the daily driver. I'd estimate the oil only does around 2000Km before it's changed.
Having said all that, the next performance motor I'll build will be given a straight diet of Mobil 1 synthetic oil. I plan to pay particular attention to bearing clearances, and want a better than mineral oil protection. Again, this will be a low Km/year engine, so the cost of the oil is offset by this fact.
I have had some bad experiences using the Pennzoil brand of products, and while I can't attribute their problems in association with the oil, I'm not willing to take the chance again - diff rebuilds can become tedious!
I'd propose an oil pressure that drops down to 0psi after a hard run, needs definate attention to the oiling system, both in the type of oil used, the oil return galleries, and the oil temperature.
Jason
Re: 18rg oil-whats everyone using? Thu, 18 December 2003 05:22 Go to previous message
cheers clint
i change my oil every 5ooo km and filter 10000km religiously
Previous Topic:W5* box on Sprinter .....
Next Topic:w58 ratios
Current Time: Sat Nov 21 20:31:37 UTC 2026
Total time taken to generate the page: 0.009026050567627 seconds
