Classifieds » Miscellaneous » Gearbox and info needed asap
sprintin
Gearbox and info needed asap Wed, 17 December 2003 11:53 Go to next message
Hi all,
My gearbox died on me the other night. I have an aus spec ae86. I would like to get a gearbox that is a bit stronger in preparation for an engine conversion. Does anyone have anything available in good nic? What would you recommend to fit to a 4ac?
Otherwise if anyone has an aus-spec ae86 gearbox in good nic please let me know. My email address is bhorner@qantm.com.au
Prefer in QLD.
Cheers..
Ben
[Updated on: Wed, 17 December 2003 11:54]
faulksy
Re: Gearbox and info needed asap Wed, 17 December 2003 20:36 Go to previous messageGo to next message
i'd stick with the t50 until your ready for the conversion or be prepared to spend big $$$ now. also would have to wait a considerable time for a fabricated bellhousing to be made unless you can find one
sprintin
Re: Gearbox and info needed asap Thu, 18 December 2003 00:53 Go to previous messageGo to next message
Excuse my ignorance but what is a t50 out of? Are you referring to the stock aus-spec box?
How much would I be looking at to get another in good nic?
Callifo
Gawler, SA
Re: Gearbox and info needed asap Thu, 18 December 2003 01:20 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=25468&start=0&rid=3270&S=f9110c2af8a 7eb6ced990e8572f3907a
Theres another t50 which is in good condition as it says. But I suppose thats an example because he wont send interstate.
[Updated on: Thu, 18 December 2003 01:24]
faulksy
Re: Gearbox and info needed asap Thu, 18 December 2003 01:41 Go to previous messageGo to next message
t50 were in both jap and aus spec sprinters. found in some celicas aswell i believe
faulksy
Re: Gearbox and info needed asap Thu, 18 December 2003 03:53 Go to previous messageGo to next message
forgot to add the usually going price is around 400-450
NickAE86
Brisvegas
Re: Gearbox and info needed asap Thu, 18 December 2003 04:11 Go to previous messageGo to next message
what sort of engine are you looking at putting in?
personally i'd go with a t-50 & adaptor plate for a w* series bellhousing so that way you can chuck in a supra g/box and not have to worry about it breaking
alternatively you can source a modified w* series bellhousing (good luck)+ g/box
or just stick with the t-50 and replace as you go
sprintin
Re: Gearbox and info needed asap Thu, 18 December 2003 13:23 Go to previous messageGo to next message
Probably either just a 4age or I might go for a 1ggte conversion!
How much are the supra gearbox's and are they hard to get a hold of?
7M-Brisbane
Re: Gearbox and info needed asap Fri, 19 December 2003 13:33 Go to previous messageGo to next message
Replace the stock box with another stock box for a few hundred bucks.
A gearbox conversion will cost you in the order of $1500 if you can't find the parts second hand... why bother when your new engine is going to come with a suitably stronger box?
sprintin
Re: Gearbox and info needed asap Sat, 20 December 2003 08:03 Go to previous messageGo to next message
Yep I think I will go the replacement t50...anyone have one in good nic for sale?
Thanks everyone.
sprintin
Re: Gearbox and info needed asap Mon, 22 December 2003 10:11 Go to previous messageGo to next message
Anyone know if the gearbox out of a ta22 is the same as the aus-spec sprinter???
FKN16V
NSW, East Coast
Re: Gearbox and info needed asap Mon, 22 December 2003 10:45 Go to previous message
For some reason i think the splines are different in the ta22, but im only 80%.
I think the ta22 has 22 splines and a sprinter t50 only has 20, or the other way around, i could be wrong thou, do a search you never know what you might find.
Previous Topic:JZX81 half cut at Just Jap
Next Topic:AE86 Garage Sale, lots of rare parts
Current Time: Fri Nov 20 21:53:24 UTC 2026
Total time taken to generate the page: 0.030128002166748 seconds
