Toymods » Tech & Conversions » 2JZ TTC mod: thumbs up!
2JZ TTC mod: thumbs up! Wed, 17 December 2003 12:58 Go to next message
I decided to try the True Twin Conversion (TTC) on my Supra tonight. For those not familiar with the theory:
http://www.mkiv.com/techarticles/ttc/ttc.htm
Basically it disables the sequential system and makes the turbos spool up in parallel, just like the 1JZ. And what's the point of this you ask? Surely this will just make it more laggy without actually increasing power?
That's what I thought as well, but I've been having intermittent boost problems lately which I assumed was something screwing up with the sequential system, so I thought I'd give the TTC mod a go and see if it fixed the problem. It's piss-easy to do, basically there are two vac lines that need to be re-routed and that's it!
The first thing you notice is the exhaust is heaps louder; this is because the exhaust is fully opened up and isn't trying to squeeze through one tiny exhaust housing. The second thing you notice is the increased off-boost throttle response, no doubt due to the better flowing exhaust. The third thing you notice is no more boost below 2500rpm, but it is making 5psi before 3000rpm and full boost by 4000rpm. The best part about this is the way it smoothly and progressively builds power, without any of the crazy peaks and troughs introduced by the sequential fandanglery.
So is it worth doing? Well in my case yes. At the end of the day it's a 3 litre engine in a 1300kg car so the increased lag isn't a problem at all. The better throttle response is a real bonus and makes it easier to drive the car smoothly in traffic. And on the highway, absolute magic - if you're in the right gear full boost is available instantly, and it simply rockets away, no hiccups and no hesitation! Would it be worth doing in a Mk4? Not sure about that, the extra weight might make it a bit sluggish in some circumstances... then again you have a 6-speed box so it should be easier to keep it in the right gear at all times! I guess it would be a case of try it and see. If anyone would like to loan me a TT Mk4 for a few days I'd be happy to try it out... all in the name of science of course. Wink
I originally planned to try the TTC mod for a day or two and then change it back, but I think it will be staying this way from now on. Lag is cool! Smile
ra23celica
Re: 2JZ TTC mod: thumbs up! Wed, 17 December 2003 13:18 Go to previous messageGo to next message
Well done Norbie.
I had read somewhere that the TTC conversion that was done in a Mk4 did make it sluggish/laggy at low revs, but then you have another 300kg to get up and bogie with in one of those. In a Mk 3 it sounds like it is magic - great stuff !
Mitch.
Re: 2JZ TTC mod: thumbs up! Wed, 17 December 2003 13:23 Go to previous messageGo to next message
or in a mk2 like norbie has Smile
ra23celica
Re: 2JZ TTC mod: thumbs up! Wed, 17 December 2003 13:24 Go to previous messageGo to next message
Oops - yes sorry - he does - confused myself. Embarassed
Thanks.
Mitch.
Allan
Re: 2JZ TTC mod: thumbs up! Wed, 17 December 2003 13:47 Go to previous messageGo to next message
would not be a mod for a MkIII thats for shure Razz
wastegate
Gold Coast
Re: 2JZ TTC mod: thumbs up! Thu, 18 December 2003 00:29 Go to previous messageGo to next message
Told you it would be better!! Very Happy
jase
Re: 2JZ TTC mod: thumbs up! Fri, 19 December 2003 05:53 Go to previous messageGo to next message
Are you going to drill out the second turbo's wastegate to seperate the turbos?
Rather than use the second turbos wastegate as a control valve?
Re: 2JZ TTC mod: thumbs up! Fri, 19 December 2003 09:31 Go to previous messageGo to next message
Nah, can't be bothered. This seems to work ok for now. Smile
7M-Brisbane
Re: 2JZ TTC mod: thumbs up! Fri, 19 December 2003 22:44 Go to previous messageGo to next message
I won't comment too solidly until I see a dyno figure Smile
Re: 2JZ TTC mod: thumbs up! Sat, 20 December 2003 08:20 Go to previous messageGo to next message
I never said it had any more power, did I?
BlackSupra
Re: 2JZ TTC mod: thumbs up! Sun, 21 December 2003 10:14 Go to previous message
21st Century Performance By Julian Edgar.
Refer to page 184.
Previous Topic:QUICK! NEED MA70 HELP!!!
Next Topic:O/D light wont stop flashing (ma70 turbo) ?!?!
Current Time: Sat Oct 17 23:02:55 UTC 2026
Total time taken to generate the page: 0.0044498443603516 seconds
