Toymods » Tech & Conversions » car problems....urgent
ta23
car problems....urgent Wed, 17 December 2003 13:12 Go to next message
I have a 3TGTEU in a TA23 and I currently my car wont start. When I turn the key my car will start and kick over but will only stay on idle for like 3 seconds and if I try and give it some revs it will die instantly.
I had an issue with the with the car starting a little while ago and was told by a mechanic after numerous tests that I had a leaking injector.
Could this problem be that the injector has started to leak even more, causing the motor to be totally flooded before I start it? Would cleaning the injectors solve this problem? Could it be another problem if so, what?
Any information would be greatly appreciated as I am stuck without a car until this problem is fixed.
Thanks in Advance
Re: car problems....urgent Wed, 17 December 2003 14:12 Go to previous messageGo to next message
I dont beleive so.
You can still run a 4cyl engine on 3cyls, so if one was flooded, it would run crap, but run
Check wiring to AFM, TPS, etc etc, vacuum lines, and can you do a diagnostic check?
sideshow
Re: car problems....urgent Wed, 17 December 2003 14:34 Go to previous messageGo to next message
that is a common prob on a 4ag if th efuel pump stops
pull th ereturn line from car and put it into a bucket
start car and see if fuel pissed out of return
this will tell u if u are gettin fuel
if the fuel stops b4 engine stops then yr airflowmeter is not triggering the fuel pump
bypass fuel pump relay to trial test it
ta23
Re: car problems....urgent Thu, 18 December 2003 01:30 Go to previous messageGo to next message
Thanks guys I will give those ideas a go.
No i dont know how to do a diagnostics test, my mate should know how though.
Allan
Re: car problems....urgent Thu, 18 December 2003 01:48 Go to previous messageGo to next message
sounds like fuel pump, normaly at idle theres enough vac to suck fuel out of the injectors to idle open the throttle and it dies
Allan
ta23
Re: car problems....urgent Thu, 18 December 2003 05:56 Go to previous messageGo to next message
Allan wrote on Thu, 18 December 2003 12:48
Allan
Even if I dont open up the throttle it still dies, could it still be the fuel pump? If so what would be the best way about testing the fuel pump?
BTW the fuel pump still makes its whining noise when running.
[Updated on: Thu, 18 December 2003 05:57]
Re: car problems....urgent Thu, 18 December 2003 06:42 Go to previous messageGo to next message
If your car runs for a few seconds and dies, I'd bet money the injectors aren't firing at all but the cold start injector keeps the engine going for a few seconds at a time. Try disconnecting the cold start injector and see if it runs then.
ta23
Re: car problems....urgent Thu, 18 December 2003 10:15 Go to previous messageGo to next message
Thanks, I will give it a go, hopefully my mate (who knows a bit more about motors than me) will come and give me a hand tommorrow.
RollaGTi
winmalee
Re: car problems....urgent Fri, 19 December 2003 12:44 Go to previous messageGo to next message
My 4afe was doing exactley the same thing. turned out to be the fuel filter. coudn't even get air through it. mechanic said the pump could be on the way out too but it was going fine when i got rid of it.
ta23
Re: car problems....urgent Tue, 23 December 2003 13:58 Go to previous messageGo to next message
Found my problem, one of the pipes from the fuel tank had a hose clamp that was too big and it was leaking out small amounts of fuel, put on a new clamp and away she went.
Thanks for any help that was given Smile
FKN16V
NSW, East Coast
Re: car problems....urgent Tue, 23 December 2003 14:38 Go to previous message
So much for the leaking injector, some mechanics?
Previous Topic:Sx Acceleration is stuffed!
Next Topic:dash - what to use on it.
Current Time: Fri Oct 23 10:32:51 UTC 2026
Total time taken to generate the page: 0.0055561065673828 seconds
