Toymods » Tech & Conversions » line lockers
stradlater
Arthurs Creek, Victoria
line lockers Thu, 18 December 2003 05:17 Go to next message
I'm just curious to know what people use for line lockers. I'm looking to put a line locker on the rear of my car to assist in stationary burnouts. Just curious if anyone has done one on a ra23 or some such.
EVOSTi
cambo
      no
Re: line lockers Thu, 18 December 2003 08:46 Go to previous messageGo to next message
hose clamps Smile or if you want somethingh more permanent i think ive seen some shops selling kits for them, maybe rare spares or something? they are illegal however.
Re: line lockers Thu, 18 December 2003 09:59 Go to previous messageGo to next message
what you need is a either a toggle valve, or a ball valve. preferably a ball valve due to the hydraulic pressure.
Swagelok has a number of items that will fit, but you will need to work out how to fit it into the brake-line with adaptors and such.
this better not be for a street car.
if it is, just cut the rear brake line, you will be much better off, and i'll feel much better Wink
if it is for an occasional drag car, you could just make up a fitting for the rear brake output on the master, and block up the line to the rear brakes. that way you can undo it when you get to the track, and refit it (and bleed it) when you leave.
Re: line lockers Thu, 18 December 2003 12:01 Go to previous messageGo to next message
Vice grips Smile
Astroboy007
Re: line lockers Thu, 18 December 2003 12:34 Go to previous messageGo to next message
vice grips everytime he wants to do a burnout ?...why not just block off the rear line
take stewarts advice
Re: line lockers Thu, 18 December 2003 15:58 Go to previous messageGo to next message
Cut the rear brake lines as they pass under the driver/passenger
Then re-route this to come up inside the cabin, inside the centre console box (just behind the handbrake)
Put a couple of on/off valves in there and re-route the lines back to where they came from
This way, so turn off the rear brakes, all you have to do is one the box, twist two valves, and your rear brakes are disconnected
This is also 100% invisible to cops.
Although, going over the pits, they are bound to see it!!
*Disclaimer. DON'T DO THIS*
Fattony
Re: line lockers Thu, 18 December 2003 19:59 Go to previous messageGo to next message
like you have trouble spinning the wheels strad
Lambolica
Northwestern Sydney
Re: line lockers Fri, 19 December 2003 06:36 Go to previous messageGo to next message
I've seen a kit for this at Rare Spares, Thourght about it for about 5 sec. too. Razz
pro_ke
adelaide
Re: line lockers Fri, 19 December 2003 09:12 Go to previous messageGo to next message
www.vpw.com.au sell them
imo they are on the same scale as lowering your car with coil spring compressors!
do you really need them anyhow? ive done plenty of stinkers in my time and ive never had major issues with the rear brakes
ab
Re: line lockers Fri, 19 December 2003 11:05 Go to previous messageGo to next message
unless of course it actually is for doing burnouts in the water at the drags.... then it's much more acceptable Very Happy... would want a hydro handbrake as well Wink mmmmm drag racing, can't wait till they bring topfuleers back to eastern creek!!
Re: line lockers Sat, 20 December 2003 04:47 Go to previous messageGo to next message
Ack, haven't any of you seen what burnouts do to your rear brakes if you don't use a line locker? Or maybe I just do slightly more severe blackstuffing that some others... or something! Evil or Very Mad
Re: line lockers Sat, 20 December 2003 04:50 Go to previous messageGo to next message
Oh yeah, old school brake shoe rivets are workable - they fit exactly inside a brake pipe, then you do it up again and nobody is any the wiser Evil or Very Mad However, I really suggest going to a speed shop and buying a proper line lock kit!
shag
christchurch nz
Re: line lockers Sun, 21 December 2003 10:46 Go to previous messageGo to next message
look into putting subaru calipers in the front they are f/wheel hand brake. makes for crap handbrake turns but. depends how much trouble you want to go to, and how paraniod you want to be about being legal, the best way is a tap on the line for the back right under the master cyl. illegal as all buggery, but thats only a problem if you crash, want insurance, or like to be able to pass vehicle inspections
stradlater
Re: line lockers Fri, 15 October 2004 03:57 Go to previous messageGo to next message
In answer to all these questions (albeit late) THe idea was to do the burnouts at the drag strip, yes, so that's why I want the line lockers..
Chris Davey
sunny coast, qld
Re: line lockers Fri, 15 October 2004 04:46 Go to previous messageGo to next message
hehe, you get lost somewhere mate Razz
Celica_John
Re: line lockers Fri, 15 October 2004 09:53 Go to previous messageGo to next message
I've heard that if you do the dodgy and use g-clamps the brake hoses can stuff up and internally collapse (something like that)
If i were you get an adjustable proportioning valve or better yet get one with a solenoid! you can mount the valve under the bonnet and run a wire to a switch inside the car.. i was considering doing this myself.. but then i thought its not like i have problems smoking it up anyway.
Mr DOHC
Re: line lockers Fri, 15 October 2004 13:02 Go to previous message
using a line locker is so much easier on the driveline and rear brakes when dropping a skid, even if its in the water at the drags
just get a proportional valve like the motorkhana boys do and just crank it all the way to the front, that way its easier to asjust and u can go to the motorkhana events too.
oldcorollas, u do realise that they will never bring fuellers back to eastern creek
Previous Topic:need your help rod 262 cam specs??????
Next Topic:SW20 -Turbo ECU in ST162 - Wiring Question
Current Time: Sun Nov 22 20:17:36 UTC 2026
Total time taken to generate the page: 0.0067191123962402 seconds
