Toymods » Tech & Conversions » Burettes for measuring piston/chamber volumes
Burettes for measuring piston/chamber volumes Thu, 18 December 2003 05:23 Go to next message
(not sure if this is the right place to post.. it is tech, and i'm not selling anything... so here goes...)
Hey all,
ever wanted a burette for measuring combustion chamber volumes?? (much more accurate than a couple of syringes)
www.livingstone.com.au has the SIMAX class B 50ml burette (graduated in 0.1mls) which is glass with a glass tip, and a teflon stopcock.
they are on special (15% off) until end of january for $33 (inc GST) + delivery ($11 for sydney, $16.50 for other cap cities, and $22 for country) or pickup from their Rosebery warehouse.
the part number is 435206725
ed_ma61
Lost in the K hole
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 06:07 Go to previous messageGo to next message
i just used a series of syringes from the hospital...
worked great, and cost me SFA Nod
id like to say that cc'ing a chamber is rocket science requiring a burette, but it aint No No No
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 06:30 Go to previous messageGo to next message
yeah, you can use syringes, but you need to consider teh innacuracy induced by filling a syringe multiple times...
for my CCV's of around 35cc, if i had a 5cc (0.1ml grad) syringe, i'd need to fill it up 7 times.. you might be out around 0.1mls each time, which totals 0.7mls, which, although it aint much, is still a fair bit (3mls = 1 compression point for me)
if you do not have the luxury of high accuracy high volume syringes, then a burette will be better... actually, a burette will always be better than a syringe, because you only fill a burette up once, so there is no inaccuracy between fills Wink
with the shitty plastic ones from chemists, that are maybe 10mls in 0.5ml grad, or 25mls in 1ml grad, the innaccuracy is too large for my liking.....
and dammit, i like glassware Razz
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 07:37 Go to previous messageGo to next message
Points to 50ml syringe (which actually has graduations to 60ml). Very Happy They are actually accurate to less than 1 cc - they have to be - overdosing people is associated with a lot of paperwork and court visits.
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 07:49 Go to previous messageGo to next message
gianttomato wrote on Thu, 18 December 2003 18:37
what are they graduated in? the burettes are in 0.1mls....
is it easy to do drop by drop with the syringe? what would you say the measurement accuracy is if you were going to measure about 30-40mls? they might be a better option if you can get to less than maybe 0.2-0.5mls accuracy...
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 09:55 Go to previous messageGo to next message
Clearly the burette is the gold standard and at around $50, a bloody good deal.
Most 50 ml syringes have 1ml graduations, but some have 0.5 ml markings (I use these if I can find them). The manufacturers will also tell you what the volume of a drop is if you ask them (so if you were pedantic enough you could actually do a drop by drop volume). Definitely not as accurate as a burette, and if you are using oil then the plastic and rubber degenerates (quite rapidly) such that the syringe is quite stiff and difficult to metre out the volume on subsequent measurements. Not an issue for those of us that can get them easily for free. It raises eyebrows amongst the staff here - I don't think they believe me when I say I need them to cc an engine! Laughing
[Updated on: Thu, 18 December 2003 10:03]
ed_ma61
Lost in the K hole
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 10:50 Go to previous messageGo to next message
yeah, what he ^^^^^^ said Nod
i used 50ml syringe to get it close to filled, and stopped on a solid graduation. then finished the fill with a 5ml syringe. worked nicely. and whilst 0.1ml tolerance probably wanst what i was aiming for between chambers, it did all work nicely.
but yeah, cheap burette!!
*recalls the days when he didnt pay for pyrex... Rolling Eyes *
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 10:51 Go to previous messageGo to next message
yeah, both my local chemist and tobacconist both think i'm a drug dealer (for syringes and those little baggies)
i guess my point with the burette is so you can match volumes between chambers and that kind of thing...
i've only ever used soapy water for CCV measurements. never tried oil. i use a 5mm thick perspex plate against the head, with 2 holes, one for water to go in, the other for air to go out... then rather than judging when the meniscus is level with the face of the head, you just see when the water is fully touching the perspex...
heh heh, i think ppl are generally paranoid Wink
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 11:11 Go to previous messageGo to next message
oh, i should have mentioned at the start, all my friends are now hassling me because
"It's all about the measuring"
Laughing Laughing Laughing Cool
and one of them had the audacity to ask me how big our fridge was (a joke unbeknownst to me) Embarassed Wink
sigh... back to my thesis hole Crying or Very Sad Crying or Very Sad
CLG
Perth, Western Australia
Re: Burettes for measuring piston/chamber volumes Thu, 18 December 2003 11:21 Go to previous message
[quote title=oldcorollas wrote on Thu, 18 December 2003 18:51]i've only ever used soapy water for CCV measurements.[/quote
Diesel works better!
Previous Topic:what car is this?
Next Topic:tach and speedo colours
Current Time: Sat Nov 21 19:57:41 UTC 2026
Total time taken to generate the page: 0.0047528743743896 seconds
