Toymods » Tech & Conversions » enhancing fuel economy
STR8 2.8
enhancing fuel economy Thu, 18 December 2003 09:31 Go to next message
as above..
5ME, what can i do to enhance the economy.
20L/100km is making me broke
V8supra
cobden /vicoria
Re: enhancing fuel economy Thu, 18 December 2003 09:51 Go to previous messageGo to next message
Well fuel economy was never real good in the first place!,but 20L/100k`s is terrible.....
What condition is your engine in?
Had the injectors cleaned lately?
Is it in a good state of tune?
Re: enhancing fuel economy Thu, 18 December 2003 13:32 Go to previous messageGo to next message
...and put the tank on a weight reduction program?
seriously, that's worse than my way-out-of-tune 18R turbo. when 's last time it had a good tune/clean up?
charles.
Re: enhancing fuel economy Thu, 18 December 2003 13:44 Go to previous messageGo to next message
Yeah time for a tune-up dude. 5M-E's are heavy on the fuel but not that heavy.
Re: enhancing fuel economy Thu, 18 December 2003 15:47 Go to previous messageGo to next message
Or convert it to W58
This will save heaps
Especially if you have a heavy foot
rob_RA40
c'town, NSW
Re: enhancing fuel economy Thu, 18 December 2003 21:49 Go to previous messageGo to next message
first step to better fuel economy lies with your right foot
look out the pun police are after me!! Shocked
STR8 2.8
Re: enhancing fuel economy Fri, 19 December 2003 01:15 Go to previous messageGo to next message
CrUZsida wrote on Fri, 19 December 2003 02:47
Confused
it already is
STR8 2.8
Re: enhancing fuel economy Fri, 19 December 2003 01:16 Go to previous messageGo to next message
ok i just thought about it,
mayb its not that bad
prob about 17l/100km
still crap.
what do you mean by tune up, is there much i can do with efi?
Re: enhancing fuel economy Fri, 19 December 2003 01:25 Go to previous messageGo to next message
17L/100km is still bad
my 6MGE with a 4.1 diff can get about 9L/100km on a country run, and thats a W57
I know the 5ME is worse, but not that bad
you should be getting about 12L/100km hiway, and at absolute worst 15L/100km city
Re: enhancing fuel economy Fri, 19 December 2003 01:28 Go to previous messageGo to next message
STR8 2.8 wrote on Fri, 19 December 2003 09:16
Go to Jaycar, get a air/fuel mixture meter (unless you can find one somewhere else, put in an o2 sensor and see how rich you are running.
Check for leaks in the intake piping, see how dirty your air filter is, check you plugs/leads.
If you are down on power, you will tend to have a heavier foot, ad hence use more fuel
STR8 2.8
Re: enhancing fuel economy Fri, 19 December 2003 01:46 Go to previous messageGo to next message
cool thanks guys
wilbo666
Re: enhancing fuel economy Fri, 19 December 2003 02:17 Go to previous messageGo to next message
My economy is crazy at the moment, last two tanks I got just over 9k / L (cheering!), the first tank was about 1/2 highway / city. The second tank was about 1/6th highway / the rest city (was soooo happy with that).
But this tank Shocked even tho my driving style hasn't changed much / if at all, and I'm looking to get about 7k / L off of this tank Confused
Btw before you all go and get angry at my good economy, the engine has only done about 20 000k since i rebuilt it Very Happy
wilbo666
Re: enhancing fuel economy Fri, 19 December 2003 02:19 Go to previous messageGo to next message
[quote title=CrUZsida wrote on Fri, 19 December 2003 12:28]
LOL which 5m-e isn't down on power!
BlackSupra
Re: enhancing fuel economy Fri, 19 December 2003 05:27 Go to previous messageGo to next message
STR8 2.8 wrote on Thu, 18 December 2003 20:31
1) Park it in the garage
2) Lock garage door
3) Walk to work
4) Very Happy
Re: enhancing fuel economy Fri, 19 December 2003 11:14 Go to previous messageGo to next message
STR8 2.8 wrote on Fri, 19 December 2003 11:16
get injectors professionally cleaned
replace or clean (if re-usable type) air cleaner
replace plugs
replace plug leads
set IGN timing to factory settings
get mech/EFI-mech to check that AFM is working correctly
get mech/EFI-mech to check that TPS is positioned correctly
replace oil & oil filter
if automatic, get gearbox serviced
check tyres at correct pressure
check brakes not dragging
checl wheel bearings are quiet/ not dragging
enough to keep you busy for your holiday? Very Happy
charles.
ZZT231
melbourne.vic.au
Re: enhancing fuel economy Fri, 19 December 2003 12:49 Go to previous messageGo to next message
as above..
That is not bad... I have had my 5M-E engine head reconditioned and still looking for enhancing my economy... I have learnt to drive sensable and not heavy footed.
I have replaced everything and even running an original Toyota air filter (yep ~ Took K&N out as it guzzled more fuel for my driving)
You just have to see if the exhaust to see if there is sufficent flow but not too much flow (don't know if it has to do with anything Embarassed )
Currently I averaging around 12-15L per hundred including mostly City driving...
Hope that helps.
Cheers.
Allan
Re: enhancing fuel economy Sat, 20 December 2003 01:34 Go to previous messageGo to next message
look at an LPG closed loop controler and see if you can set it up to bypass air around the AFM to give the ol' 5m leaner runing on the hi-way/cruise
Allan
STR8 2.8
Re: enhancing fuel economy Sun, 21 December 2003 03:43 Go to previous messageGo to next message
how much does injector cleaning cost?
ZZT231
melbourne.vic.au
Re: enhancing fuel economy Sun, 21 December 2003 04:30 Go to previous messageGo to next message
STR8 2.8 wrote on Sun, 21 December 2003 14:43
You are looking around $25 per injector...
Cheers.
ae82rollaboy
Re: enhancing fuel economy Sun, 21 December 2003 04:39 Go to previous messageGo to next message
shite..
i've just realised how much of a problem i have.. cos this is nothing compared to how much fuel i use.. mine takes about 6 litres for every 10 km--and its just a mainly stocky 4ag. i knew its running too rich, but if you guys are saying that 20litres per 100km is bad then 60 litres per 100km in a 1.6 4cyl is f*cken apalling!!! ARGH
does anyone know if theres a lean-rich adjustment screw on the 4ag? please help--im having to mortgage my left testicle just to get around!
soz dude, i didnt mean to hijack your thread Confused so if anyone can help me out could you please please please pm me with any advice?
========cheers, roman http://www.click-smilies.de/sammlung0903/weihnachten/xmas-smiley-022.gif========
ZZT231
melbourne.vic.au
Re: enhancing fuel economy Sun, 21 December 2003 11:59 Go to previous messageGo to next message
ae82rollaboy wrote on Sun, 21 December 2003 15:39
... can help me out could you please please please pm me with any advice? ...
Take your car to a Gas Research place or a good Dyno place. It may be that the jets in the carby and needs a reco.
My SA63 (2S-C) was doing 15L per hundred until we did the heads (Oil Stems) and the carby reco, now she does 9L per hundred [And Gas Research].
See how you go.
Cheers.
STR8 2.8
Re: enhancing fuel economy Sun, 21 December 2003 13:34 Go to previous messageGo to next message
ae82rollaboy----> no wukka's champ
sounds like u really need some help with that fuel economy Very Happy
Re: enhancing fuel economy Sun, 21 December 2003 14:17 Go to previous messageGo to next message
He'd running a 4AG, so no carbies.
Also, if the catalytic converter is blocked your car will use a huuuuge amount of fuel
Drop into a zorst shop and have them check that
ZZT231
melbourne.vic.au
Re: enhancing fuel economy Sun, 21 December 2003 14:54 Go to previous messageGo to next message
CrUZsida wrote on Mon, 22 December 2003 01:17
I met him in person and thought he drove a AE82 Hatch with a 4A motor... Oh well Embarassed
Cheers.
Re: enhancing fuel economy Mon, 22 December 2003 05:50 Go to previous messageGo to next message
ae82rollaboy wrote on Sun, 21 December 2003 12:39
shite..
Just to put that in perspective, the Toyota GT-one Le Mans car used about 50l/100km under full racing conditions and that had 400kw+ Razz
coronamark2
Re: enhancing fuel economy Mon, 22 December 2003 06:06 Go to previous messageGo to next message
you should count your self lucky
try having a 4m with a 350 holley Razz
it sux's the juice it cost me $10 a day to get to work and back Laughing
but thats probably because i have my foot flat for half of it Very Happy
but it should be better when i get the a/f ratio right all you can smell is fuel coming out the exaust.
ae82rollaboy
Re: enhancing fuel economy Thu, 25 December 2003 04:14 Go to previous messageGo to next message
thanks for all the advice guys.. keep it coming! shite--i wish i'd checked the cat-i replaced a threaded bolt on it the other day when i was bored.
and zzt231--i did have a 4ac hatch for a bit, but that was a long way back. yeah ive got a 4ag now...but at the rate i'm going i'll probably have to sell it cos i cant afford the fuel! Very Happy
i know the car's running really really rich.. is there a way that i could lean it out? is there some sort of adjustment mechanism to do this on an efi motor? i know that it's possible to do on a carby Rolling Eyes or otherwise, does anyone have any ideas as to why it could be running so rich??
thanks again for all your help guys---oh and merry christmas
=============cheers, roman http://www.click-smilies.de/sammlung0903/grinser/grinning-smiley-043.gif============
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: enhancing fuel economy Thu, 25 December 2003 05:25 Go to previous messageGo to next message
6L per 10km cant be right, thats a uber shiteload of fuel!
how about doing some of the aboveformentioned tune up tricks and then let us know how it is then.
STR8 2.8
Re: enhancing fuel economy Sun, 25 January 2004 08:27 Go to previous messageGo to next message
well happy news,
5ME just completed a 488km tank Very Happy
mostly highway driving, after replacing fuel filter, air filter, and running LRP
yay!
Allan
Re: enhancing fuel economy Mon, 26 January 2004 01:44 Go to previous message
Lose the LRP dude its crap use PULP, and also see about winding up the advance on the dizzy a few degrees (listen for pinging then back it off a little) you may get even better mileage!
Allan
Previous Topic:just athought- changing from 2xct12's to 1x bigger turbo
Next Topic:3SGE into RA2x
Current Time: Mon Nov 2 06:07:29 UTC 2026
Total time taken to generate the page: 0.0098650455474854 seconds
