Toymods » Tech & Conversions » 1J Tacho
Wildsupra
1J Tacho Thu, 18 December 2003 10:40 Go to next message
A few months ago i bought a JZA70 half cut and put engine, gearbox (m/t) and front cross member in my MA70 supra. Still to this day i have not been able to get my F*CK!IN tacho working. This includes opening my original dash and the analog dash that was in the half cut and swapping the tachos, which appeared to be exactly the same anyway. My MA70 was origanally a N/A 7m. Anyone know how the hell i can get my tacho working? I like to rev hard but i dont like hitting the limiter to often!!! i need my tacho!!!! PLEASE HELP Confused
pimp1j
Re: 1J Tacho Thu, 18 December 2003 15:36 Go to previous messageGo to next message
You will need a Tacho converter... Grant from sixworks sells them. Do a search for previous posts on this topic.
Grant
Newcastle, NSW, Australia
Re: 1J Tacho Thu, 18 December 2003 20:48 Go to previous messageGo to next message
Wildsupra,
If you swapped the tachos over and it still does not work then you haven't connected the tacho wire correctly. If you still can't get it working correctly and you are in Sydney, contact Jim (aka Sideshow on this forum). He should be able to locate it in no time.
Grant
lumpy
Adelaide, SA
Re: 1J Tacho Thu, 18 December 2003 22:54 Go to previous messageGo to next message
As Grant said, if you are using the half-cut tacho and it's not working you must have wired it incorrectly. I've done exactly the same conversion to mine, and although the jza and ma tacho drives look identical, there is a little board on them that has different components. We swapped this over on mine, and used the Ma70 tacho/needle combo with jza backing plate to keep it looking stock.
wastegate
Gold Coast
Re: 1J Tacho Fri, 19 December 2003 00:08 Go to previous messageGo to next message
pimp1j wrote on Fri, 19 December 2003 02:36
Ahhh no you don't.. only on 4 cylinder tachos to you need a converter.
As others have said, check your wiring.
bbaacchhyy
Re: 1J Tacho Fri, 19 December 2003 00:10 Go to previous messageGo to next message
wastegate wrote on Fri, 19 December 2003 11:08
Ahhhh, sorry, your'e wrong. The Tacho converter is not for different cylinder numbers, it is for the type of signal.
The product should be called Tacho Signal Converter. I'm about to get one for my MA61 with 7M-GTE
Oooroo
Michael B
Grant
Re: 1J Tacho Fri, 19 December 2003 00:34 Go to previous messageGo to next message
The product we sell is called a Tacho Booster because it 'boosts' the 12volt square wave signal to several hundred volts to drive coil type tachos. True, the waveform is changed but frequency remains the same. Depends on how technical you want to get.
Our new product, to be released early in the new year, will have the capability to alter frequency as well as boosting the signal.
bbaacchhyy
Re: 1J Tacho Fri, 19 December 2003 00:37 Go to previous messageGo to next message
Grant wrote on Fri, 19 December 2003 11:34
Grant,
Thanks for the clarification. For my MA61 with 7M-GTE, does it matter if I get a new or old unit ? Is there a price difference ?
I'll get of my considerable ass and order one shortly - as soon as I get an answer Very Happy
Michael B
Grant
Re: 1J Tacho Fri, 19 December 2003 00:41 Go to previous messageGo to next message
Yes, there will be a price difference but you really only need to boost the signal rather than change frequency so you'd be best to buy the current model. In any event, both models will be available, the new one will not replace the old, simply provide the extra functions of frequency division/multiplication for those who need it.
Hope this helps.
Grant
bbaacchhyy
Re: 1J Tacho Fri, 19 December 2003 00:58 Go to previous messageGo to next message
An order has been sent by fax, Cheer Grant.
Wild Supra, sorry for the thread hijack, but hopefully you get it sorted soon
Michael B
pimp1j
Re: 1J Tacho Fri, 19 December 2003 01:53 Go to previous messageGo to next message
ahhhh... who's saying ahhh now Wink hehe.
Grant i'm going to buy myself a 'booster' for xmas... i'll call u this week.
wastegate
Gold Coast
Re: 1J Tacho Fri, 19 December 2003 04:31 Go to previous messageGo to next message
Perhaps I should make myself alittle clearer huh?
You DON'T need a "Tacho converter" if the EFI tacho is going from a 6 cylinder to a 6 cylinder.
sideshow
Re: 1J Tacho Fri, 19 December 2003 08:12 Go to previous message
best thing to do is recheck where the wiring went on the dash that the engine came out of
the blck wire with brown rings on it every 2cm is the tacho signal
it should come from the ignitor
then u should either have a black with orange stripe
or a black with yellow strip
these are ignition wires on toyotas
they are bit fiddly to do vbecause the wires dont go directly to tacho
the tacho has screws in the back and the power runs thru the screws
just go over it all
u could also get the signal wire and attach a very long wire to it and connect it to another car runnin beside it
connect it to its neg coil
if it still doesnt work the tacho then the wiring is out
if it works the tacho then the signal to tacho is not there
by the way tacho boosters will not change a 4 cly to work on a 6 or orther way round
there are 6 cyl tachos for single coiled engines
and their are 6 cyl tachos for multi coil engines
the multi coiled engines have to weak a signal to run the single coil tachos
and thats all the tacho booster does
unless there is a new model that can do both
[Updated on: Fri, 19 December 2003 08:14]
Previous Topic:M engine bits swapin?
Next Topic:1JZ Single Turbo Conversion - for Tech Conversion discussion
Current Time: Wed Nov 18 17:19:45 UTC 2026
Total time taken to generate the page: 0.0084939002990723 seconds
