Toymods » Tech & Conversions » home turbo rebuild?
haydennz
home turbo rebuild? Sat, 20 December 2003 04:05 Go to next message
remember i said i had 2 x ct20, well stripped em both picked the best bearing etc comepletly cleaned up, spottless.. and now I have put it back togeither, couple of concerns tho.
it now spins extremely freely, as in give it a decent spin with your fingers and it will continue doing 5-6 rotationa where as before it would stop very quickly.
2nd, are the journel bearings ment to be a very tight fit into the housing or do the journing bearings spin a little also?
[Updated on: Sat, 20 December 2003 04:06]
sideshow
Re: home turbo rebuild? Sat, 20 December 2003 04:36 Go to previous messageGo to next message
really u should get it done professionally
the centre turbines need to be balanced
if they arent
they could do alot of damage if they let go at 150000 rpm on the turbo
so spendin 500 on a turbo is nothing compared to 3000 on an engine
CLG
Perth, Western Australia
Re: home turbo rebuild? Sun, 21 December 2003 13:35 Go to previous messageGo to next message
Yep, provided both the turbine and comp wheels have no damage on them (ie weigh the same as when they were last balanced), if you haven't marked the balance for the comp wheel, when reassembling they will need to be balanced professionally. Most workshop won't want to do it without installing new bearings and seals any way. Reassembling without knowing the balance will be like driving around with unbalanced road wheels - only worse and more expensive for the turbo!
haydennz
Re: home turbo rebuild? Sun, 21 December 2003 13:37 Go to previous messageGo to next message
sideshow was right, after getting the compressor housing back on etc, i found noticible wobble/bent shaft? so ive binned it, cars off the road till i found a suitible replacement turbo.
STR8 2.8
Re: home turbo rebuild? Sun, 21 December 2003 13:39 Go to previous messageGo to next message
wat about mr 'CLG'
thanks to him too for his input
Very Happy
edit: im not being sarcastic, just thought someone deserved recognition for assistance.
[Updated on: Sun, 21 December 2003 13:40]
haydennz
Re: home turbo rebuild? Sun, 21 December 2003 13:41 Go to previous messageGo to next message
yes he continunies to be extremely helpfull ;0 - not being sarcastic either.
CLG
Re: home turbo rebuild? Sun, 21 December 2003 15:40 Go to previous messageGo to next message
Embarassed Stop!, ..., I'm blushing! Shocked Laughing
Put the turbos to one side you can still use parts from them to resurrect other CT20's with minor problems if you find one, for example, with a damaged comp wheel.
EVOSTi
cambo
      no
Re: home turbo rebuild? Mon, 22 December 2003 10:18 Go to previous message
or you could just give it/them to me Very Happy
Previous Topic:could someone tell me..(sprinter conversion)
Next Topic:6MGE Bottom end part nos
Current Time: Tue Oct 13 22:06:22 UTC 2026
Total time taken to generate the page: 0.040150880813599 seconds
