Toymods » Tech & Conversions » 4AGE SQUEALING! under light acceleration?
de_rift
Wollongong
4AGE SQUEALING! under light acceleration? Sun, 21 December 2003 00:06 Go to next message
Ok its an ae86 running a bigport aw11 4age.
I have just replaced my whole cooling system:
water pump
belt
radiator
hoses
So that is one thing that is eliminated...
It will only do it when lightly revving the engine from idle ie at traffic lights to take off. It will emit a nastily loud squeal (enough to make your ears ring if your above the engine bay.)
It will go away after about a second, but it is annoying the shit out me, not to mention my landlord.
I suspect it may be my timing belt tensioner pulley, as I tightened it the other day and it made one noise go away (sort of a clicking sound like a dying rocker), and since this noise has arisen. I have one from a 100kW engine spare, are these interchangeable (I haven't had the time to check this so I thought I would check before I replace another part that is working fine.)
Any Ideas??
krayzie
Re: 4AGE SQUEALING! under light acceleration? Sun, 21 December 2003 00:19 Go to previous messageGo to next message
Sounds like a loose belt somewhere.
Shraka
Re: 4AGE SQUEALING! under light acceleration? Sun, 21 December 2003 05:54 Go to previous messageGo to next message
My friends Magna does this at startup. Sounds realy bad.
hotrolla
Re: 4AGE SQUEALING! under light acceleration? Sun, 21 December 2003 06:09 Go to previous messageGo to next message
Shraka wrote on Sun, 21 December 2003 16:54
My mum and about 10 other magna's that i know of make that start
up rattle .
Bloody magna's
V8_MA61
Re: 4AGE SQUEALING! under light acceleration? Sun, 21 December 2003 06:43 Go to previous messageGo to next message
It'd be a loose belt for sure.
Same thing happened to me when i changed the belt/ water pump on my old 5m. It was fine until the belt wore in and then it became too loose and squealed really bad..especially at night with all the moisture in the air.
Blake
EVOSTi
cambo
      no
Re: 4AGE SQUEALING! under light acceleration? Sun, 21 December 2003 11:04 Go to previous messageGo to next message
i dont think its the timing belt tensioner but they will interchange. i would say it is more than likely the tension of the altenator belt. tighten it up a little and spray some belt grip on it.
ae82rollaboy
Re: 4AGE SQUEALING! under light acceleration? Tue, 23 December 2003 06:55 Go to previous messageGo to next message
sounds to me like the alternator belt needs tensioning dude. happened to me a while back Shocked
onejayzed
Re: 4AGE SQUEALING! under light acceleration? Tue, 23 December 2003 07:33 Go to previous messageGo to next message
retension all your 'v' belts (ie water pump/alternator/clutch fan etc). if you think it's tight, then tighten it some more. use a lever of some kind to tension the belt (ie pull down on the alternator or whatever). 5.0cm of play is about right for a 'v' belt at full tension.
while the engine is running, put a candlestick against the belt on the contact side to condition it after all the slippage, otherwise you'll have a shorter belt lifespan. not that it'll do any damage, just saves having to replace a belt more often.
purpleminiep
Mentone
Re: 4AGE SQUEALING! under light acceleration? Sat, 27 December 2003 09:53 Go to previous message
Part of the works Mini's tool kit was a pretensioned fan belt which the driver co-driver had ti change during the rally when rallies lasted a decent time. They actually stretch quite a bit even newly manufactured ones. Retension your belts or use some drilube while the car is running on the belts.
Brad
Previous Topic:1GGTE Temperature readings...
Next Topic:Compressor for spray painting
Current Time: Sun Oct 25 23:28:42 UTC 2026
Total time taken to generate the page: 0.18380188941956 seconds
