Toymods » Tech & Conversions » cylinders full of oil!!! PLEASE HELP!
ae82rollaboy
icon9.gif  cylinders full of oil!!! PLEASE HELP! Sun, 21 December 2003 04:58 Go to next message
hey guys,
i've had a hesitation problem for a while in my ae82 twincam..where when i went to change gears the car just half dies it feels almost like complete power cut for a split second and then it goes again.
this only happened sometimes--on complete flatstick gearchanges it was fine, and when i was driving like a pensioner (giving it a second between gears) it was fine too, but in between these two, it jolted like a bitch.
i pulled out my sparkplugs today, and the tips were absolutely DRENCHED in oil. oil was, like, dripping off em when i pulled them out. i looked into the cylinders, and i could see heaps of oil down there also.
the thing is, that the car never blew any blue smoke (not under acceleration, or after long idling periods...and i'd checked the compression not that long ago and it was fine), only a bit of black smoke, cos its running mega rich at the mo. but when i cleaned the plugs and put them back in and started her up it blew an absolute shiteload of smoke.
could this be the reason for the hesitation? that the tips of the plugs are getting fouled with oil? and if so, WHERE IS THIS OIL COMING FROM? and WHAT CAN I DO TO FIX IT? and before you say it...no, i didnt overfill the oil.
please help me!!!!!!!!!!!
==========cheers, roman http://www.click-smilies.de/sammlung0903/weihnachten/xmas-smiley-022.gif==============
IRA11Y
Club Member
Re: cylinders full of oil!!! PLEASE HELP! Sun, 21 December 2003 05:28 Go to previous messageGo to next message
most likely is that you didnt notice all the oil sitting around the spark plugs BEFORE you pulled them out.... was the plug socket also covered in oil?
its pretty common for the cam cover seals to leak and the galleries fill up with oil. Replace the seals and see if that fixes the problem.Generally you will not see liquid oil in a chamber unless the engine wont run at all unless for the above reasons.
make sure you get all the oil out by cranking without the plugs in, MAKE SURE NO ONE LOOKS IN TO THE CYLINDERS WHILST CRANKING OR IT MAY RESULT IN LOOSING AN EYE!!!, place some absorbant material into eack gallery to soak up the oil as it shoots out.Best to disconnect the lead from the coil while you do this.
If it turns out that this isnt the problem then youll most likely find the head and/or pistons and rings need to be rebuilt
Shraka
Re: cylinders full of oil!!! PLEASE HELP! Sun, 21 December 2003 05:44 Go to previous messageGo to next message
Shit. Sounds bad Roman. Sounds bad. If you want an extra set of hands to help you out, give us a yell and I'll see if I'm free.
Allan
Re: cylinders full of oil!!! PLEASE HELP! Sun, 21 December 2003 08:27 Go to previous messageGo to next message
Is this the under-bonnet toolbox rolla?
Classique71
Colac, Victoria
Re: cylinders full of oil!!! PLEASE HELP! Sun, 21 December 2003 08:30 Go to previous messageGo to next message
thats the one allan - lets hope its just the cam cover seals thats gone astray - they are easy enough to replace ...
otherwise - got NFI dude .. sorry
SIMDOG
Bayside Melbourne.
Re: cylinders full of oil!!! PLEASE HELP! Sun, 21 December 2003 09:54 Go to previous messageGo to next message
I think I said in another thread that my rocker cover gaskets used to leak and filled the spark plug gallery with oil... When I pulled the plugs out the oil drained into the cylinders. Sounds like that could be the same deal??? Confused
Grega
melbourne.victoria.austra...
Re: cylinders full of oil!!! PLEASE HELP! Sun, 21 December 2003 19:04 Go to previous messageGo to next message
oil will be leaking down into the valley from the cambox seals. garranteed.
SIMDOG
Bayside Melbourne.
Re: cylinders full of oil!!! PLEASE HELP! Mon, 22 December 2003 01:37 Go to previous messageGo to next message
Oh, I forgot to clarify, my oil leak problem was fixed a while ago... I was just saying what I experienced sounds like the same deal. Smile
ae82rollaboy
Re: cylinders full of oil!!! PLEASE HELP! Tue, 23 December 2003 06:52 Go to previous messageGo to next message
thats the thing...i'm pretty sure i checked the plug gallery BEFORE i took out the plugs, and it had a bit of oil residue in there, but not too much..not enough to leak into the cylinders.
and IRA11Y--you said to crank it without the plugs in there to get rid of the oil...wouldnt the oil just get burnt up anyway? or if it wont, that could be my problem, (cos i think i overfilled the oil about 3 months ago, and if it wont get burnt up in the cylinders, that might be why my plugs keep fouling, and the thing hesitates.
also, does anyone know if the 4ag dipstick is the same as a 4ac dipstick? seeing as my car is like a leggo-car, with random bits off other cars here and there, if i have a 4ac dipstick in there i may be overfilling the thing with oil all the time without even knowing it, and it seeps past the rings???
but thats the weird thing--the car blows absolutely NO BLUE SMOKE... how could that be, with oil in the cylinders??
thanks ofr all your help guys, any more advice would be really appreciated.
=====cheers, roman http://www.click-smilies.de/sammlung0903/weihnachten/xmas-smiley-022.gif===============
p.s. oh, and allan, yeah it is the same toolbox mobile you're thinking of Very Happy
IRA11Y
Club Member
Re: cylinders full of oil!!! PLEASE HELP! Tue, 23 December 2003 09:52 Go to previous messageGo to next message
that depends how much oil is in there.. a small amount will get burnt easily but if, as you have said, there is a lot of liquid oil in there, then it may be that you will get compression lock when cranking which has the potential to cause some damage. its the same effect when a 4WD drowns in a deep water hole except the compression of the water just destroys the piston and bends the valves when they crank.
lesson: fluids dont compress as easily as air
Shraka
Re: cylinders full of oil!!! PLEASE HELP! Tue, 23 December 2003 10:18 Go to previous messageGo to next message
ae82rollaboy wrote on Tue, 23 December 2003 17:52
Actualy you do/did. At the cruse I noticed a little blue smoke out the back of your exaust when you first took off. Once you where up an crusing you where smoke free, and I didn't notice any on the way back home on the freeway either.
Hope that helps. Sorry I didn't mention it earlier. Smile
[Updated on: Tue, 23 December 2003 10:18]
Astroboy007
Re: cylinders full of oil!!! PLEASE HELP! Tue, 23 December 2003 14:52 Go to previous messageGo to next message
oil in clyinders ....my guess would be piston rings are dead
i just went through that problem
when it gets worse oil spits out the exhaust on startup, hold a piece of white paper against the exhaust to examine the shit
allencr
tallahassee FL usOFa
Re: cylinders full of oil!!! PLEASE HELP! Tue, 23 December 2003 18:36 Go to previous messageGo to next message
your cylinders are fine.
the oil if from a spill when filling or a leaking cam cover - that is all!!!!
oil has NEVER spit out the exhaust on any car ever made(that still runs) unless a valve got dropped and has destroyed the head and piston.
Astroboy007
Re: cylinders full of oil!!! PLEASE HELP! Tue, 23 December 2003 22:33 Go to previous messageGo to next message
thats strange cos i have oil patches all over my driveway and several people have seen it spitting the oil out the exhaust and theres hardly any compression on the cylinder that has oil inside it, with the similiar problem of oil covering the spark plug, sometimes it only ran on three cylinders
Astroboy007
Re: cylinders full of oil!!! PLEASE HELP! Tue, 23 December 2003 22:41 Go to previous messageGo to next message
allencr wrote on Wed, 24 December 2003 04:36
your
thats a VERY bold comment to make as i have known a few cars to spit the oil from the damaged rings
RobST162
Re: cylinders full of oil!!! PLEASE HELP! Tue, 23 December 2003 23:19 Go to previous messageGo to next message
yeah mate for that volume of oil he is talking about ("dripping off the plugs") he would be blowing so much smoke his rear view mirror wouldn't see anything but it! Smile
SIMDOG
Bayside Melbourne.
Re: cylinders full of oil!!! PLEASE HELP! Wed, 24 December 2003 13:50 Go to previous messageGo to next message
allencr wrote on Wed, 24 December 2003 05:36
For the record, I have a mate with a Shitsubishi Scorpion that would spit oil out the exhaust big time on startup. His garage door has splatter marks on it. The engine has been replaced now due to worn rings and being 20 years old.
ae82rollaboy
Re: cylinders full of oil!!! PLEASE HELP! Thu, 25 December 2003 05:18 Go to previous messageGo to next message
thanks for all your help guys..
i suspect that youre right allencr-i ran a compression test yesterday and every single cylinder is exactly on 155. so i guess we can rule the rings out. i checked the plugs again and there wasnt any oil on em. so i guess it mustve leaked past the plugs into the cylinders as i was taking them out. after flushing the plug gallery with white spirit and removing all the oily residue i'll drive it for a bit and then pull the plugs again and have a gander.
but guys--HAS ANYONE GOT ABSOLUTELY ANY IDEA AS TO WHAT CAN BE CAUSING THE HESITATION??
p.s. nimrod, you say you saw a puff of smoke come outa the exhaust? are you SURE it was blue and not black? cos im running mega rich, so it was probably just fuel?
thanks for all your advice fellas, keep it coming please!
and merry christmas!
Shraka
Re: cylinders full of oil!!! PLEASE HELP! Thu, 25 December 2003 23:36 Go to previous message
It looked a bit blue, but it could have been black, and just been 'cuz you are running rich. I'm no mechanic so I dunno. Smile
I think I should do a compression test on my car.
Previous Topic:weight of 4AGE head? please
Next Topic:Opinions on this AE86 brake upgrade
Current Time: Thu Oct 29 03:10:49 UTC 2026
Total time taken to generate the page: 0.027146100997925 seconds
