Toymods » Tech & Conversions » Tercel guru's look in
CrAiGzEE
south of the big smoke
Tercel guru's look in Sun, 21 December 2003 11:08 Go to next message
just a few questions
1. when was the last model made
2. are they full time 4wd?
3. did any come with injection?
4x4 20v what yeah model is yours?
CLG
Perth, Western Australia
Re: Tercel guru's look in Mon, 22 December 2003 02:12 Go to previous messageGo to next message
Last model made was AE95, I think they were made till 1992 but don't quote me on that? Yes, they are constant 4WD, but not LSD. Available in both manual and automatic variants, they came with an east/west 4AFE running EFI, and also utilised a different block to clear the 4WD gearbox.
rob_RA40
c'town, NSW
Re: Tercel guru's look in Mon, 22 December 2003 02:32 Go to previous messageGo to next message
some interesting info here
the earlier model had a north south engine config, and a live axle rear end
CLG
Re: Tercel guru's look in Mon, 22 December 2003 02:41 Go to previous messageGo to next message
Yeah the earlier model ran a 4AC from memory, however shares the same style live axle rear end the AE95 also uses. I've heard utilising the earlier model driveline for conversions is not worth it due to their poor reliability when given mild power increases?!?
Jason
Re: Tercel guru's look in Mon, 22 December 2003 03:41 Go to previous messageGo to next message
My sister had a early model and the transmission was horrible in it it would pop out of 1st and 2nd unless you held the gearstick and when you put it in 4wd you had to sit for 10 mins rocking it back and forward to put it back in 2wd. Normal methods of taking it out of 4wd didnt work.
CrAiGzEE
Re: Tercel guru's look in Mon, 22 December 2003 04:42 Go to previous messageGo to next message
what series diff they got?
is the gearbox and trasfer case all in one?
CLG
Re: Tercel guru's look in Mon, 22 December 2003 07:39 Go to previous messageGo to next message
I had the same problem trying to get a Hilux in and out of 4WD Jas, was attributed to worn driveshafts and uni joints. We never replaced them, even though this was predominately an off road farm vehicle, as we only needed 4WD once or twice a year! I'd also suggest the detent clips needed tightening in your sister's gearbox to aid gear selection retention.
The gearbox and transfer case is a unitary item on the AE95 and runs back to a live axle rear diff.
On a side note, Toyota and many other 4WD producers recommend driving in 4WD regularly to keep the above scenario from happening, I have a friend with a twenty year old Landcruiser in excellent condition who still drives in 4WD once a month, he's never had a selection or driveshaft problem with the car. something for all the Toorak Tractor drivers out there with selectable 4WD!!!
ae95
1. i got one. they were made until 1994.
2. yep theyre all full time 4wd with a center diff lock.
3. yep they all came with injection (ae95 that is) previous model came with 4ac.
yep the ae95 has a solid rear axle
no idea about diff series
im pretty sure transfer case and gbox are one
4x4 20v has the same model as me - AE95
http://www.pbase.com/ae95fe
theres some pics of mine
[Updated on: Mon, 22 December 2003 07:40]
CrAiGzEE
Re: Tercel guru's look in Mon, 22 December 2003 13:22 Go to previous messageGo to next message
ae9 what would be the value o one like yours?
ae95
Re: Tercel guru's look in Mon, 22 December 2003 14:18 Go to previous messageGo to next message
mines a 88 model, its worth about 3k i think, i seen them go for as high as about 8k.
u thinking of modding one?
i once had plans of putting in a turbo 4agze, then i bought a sprinter.
ae95
Re: Tercel guru's look in Mon, 22 December 2003 14:22 Go to previous messageGo to next message
ps. redbook reckons they were made till 1996 although i've never seen one newer than 1994
rthy
Melbourne - NthSubs
Re: Tercel guru's look in Tue, 17 February 2004 11:58 Go to previous messageGo to next message
wats a cheap conversion for a ae95? 4age?
CrAiGzEE
Re: Tercel guru's look in Tue, 17 February 2004 12:33 Go to previous messageGo to next message
i surpose so
ae95
Re: Tercel guru's look in Tue, 17 February 2004 14:46 Go to previous messageGo to next message
theres a guy named lars with a 4agte in his ae95. first one i've seen. so far the drivetrain has held up. i would go for a 4agze, as the extra torque will help.
http://www.twincam.org/forums/index.php?showtopic= 843
rthy
Melbourne - NthSubs
Re: Tercel guru's look in Thu, 19 February 2004 10:10 Go to previous messageGo to next message
iv seen that one, pretty mad, but must have cost abit
ae95
Re: Tercel guru's look in Thu, 19 February 2004 14:57 Go to previous messageGo to next message
apparently its not much custom work.
rthy
Melbourne - NthSubs
Re: Tercel guru's look in Fri, 20 February 2004 00:05 Go to previous message
custom work as in... engine mounts, etc?
Previous Topic:Distributor and Rotor Continuity
Next Topic:Oil pipe for 3tgte
Current Time: Wed Oct 28 06:11:10 UTC 2026
Total time taken to generate the page: 0.006680965423584 seconds
