Toymods » Tech & Conversions » MA61 engine problems.....
Evil_Foetus
Ballarat, Victoria
icon5.gif  MA61 engine problems..... Tue, 23 December 2003 11:19 Go to next message
okie dokie.... my ma61 has been backfiring, so we took it to our mechanic to have a look....
it appears that the water in the radiator is frothing and bubbly, almost soapy- maybe a mix of different coolants, dunno- and we aren't sure whether there is a thermostat in there- didnt have time to check....
number 6 spark plug was oiled up, and smells like its running rich.... which would explain the backfiring.
everything seems to point to a head gasket, however pressure and dye test dont...so mr mechanico is pretty sure it aint one...
so has anyone else had these problems??
to me, it sounds almost like an oxygen sensor or something... running rich etc.... what are these like to find, install etc???
so yes. what does all this crap sound like?? if it sounds nasty, would it just be worth dropping in the 7M-GTE now?? (bad option, no money AT ALL)
thanks y'all Smile Smile
Re: MA61 engine problems..... Tue, 23 December 2003 11:28 Go to previous messageGo to next message
if the HG is blown between an oil & water gallery, the comp test will show everything to be sweet
Evil_Foetus
Ballarat, Victoria
Re: MA61 engine problems..... Tue, 23 December 2003 12:30 Go to previous messageGo to next message
hmmmmmmmm.... i see..... well ive drove it over 700kms the day i got it, would have the HG blown itself during that day?? (had to drive him home from aubury, and had to show friends new car Evil or Very Mad Evil or Very Mad )
Re: MA61 engine problems..... Tue, 23 December 2003 13:07 Go to previous messageGo to next message
well, bhg between oil & water gallery is fairly rare, unless there's a bore-gallery leak as well... but a frothy radiator is not good. any discolouration to your oil?
ZZT231
melbourne.vic.au
Re: MA61 engine problems..... Tue, 23 December 2003 13:36 Go to previous messageGo to next message
Evil_Foetus wrote on Tue, 23 December 2003 22:19
...to me, it sounds almost like an oxygen sensor or something... running rich etc.... what are these like to find, install etc???
Sorry Evil... The MA61 was not fitted with a Oxygen Sensor Smile coz the car was imported when Australia only had leaded petrol. Only after January 1st 1986, Unleaded was avaliable and mandatory for car makers to use Cool
*If No one Understand me... Please forgive me Embarassed
Cheers.
Re: MA61 engine problems..... Tue, 23 December 2003 13:38 Go to previous messageGo to next message
draven wrote on Tue, 23 December 2003 19:28
This would result in milk colour oil
very easy to pick up
Take all the plugs out and do a c/r test (when she's warm of course)
This is good to do just so you know how good the motor is (150+ is good, difference of 10 between all cyls)
Buy a new set of plugs
You dont have an o2 sensor (unless someone put in a Cressida 5mge + ecu)
Run a tank of 98
When is it back firing? at idle (a fluff or a pop?) then its the TPS or timing
Back firing when decellerating, dunno about that, its usually coz to rich, or a hole in cat/muffler, but you have no cat
Put a new set of plugs in and see how she goes
Also do a diagnostics to see if the ecu has picked up any errors
Evil_Foetus
Ballarat, Victoria
Re: MA61 engine problems..... Wed, 24 December 2003 06:35 Go to previous messageGo to next message
hmmmmmm thanks everyone....
oil colour- no discolouration.
i run premium unleaded in it all the time (optimax, 98 octane (i think)), and the new plugs were put in...
it backfires between gears, usually when driven hard... and when the foot is taken off the accelerator... but not all the time, so yeah....
3 hours on the pressure test (radiator) and was fine. tube and dye tests were all fine....
probably going to get the ECU and exhaust gas looked at next...
so basically, there is air in the system, and the coolant is frothing, so we thinks that there is a reaction between two different coolants...
V8supra
cobden /vicoria
Re: MA61 engine problems..... Wed, 24 December 2003 10:16 Go to previous messageGo to next message
I bet it`s the stupid friggin air pump!!!.....i had the same prob with my 5m.......i blocked off one side and it fixed the backfiring.
Classique71
Colac, Victoria
Re: MA61 engine problems..... Wed, 24 December 2003 10:22 Go to previous messageGo to next message
well - flush out the coolant - and replace it - see if that solves the frothyness!
then - if not - go for the more nasty of possible reasons youve mentioned ..
ill be up in ballarat soon - gotta see the new wheels Smile
Oh and i can direct you to a guy in ballarat that does a EXCELLENT job polishing the ma61 alloys - he did mine and they came up awesome + i can help you restore the onees you have Smile
haydennz
Re: MA61 engine problems..... Wed, 24 December 2003 11:02 Go to previous messageGo to next message
shove the hose down it to give it a bit of a back flush and then wollah you will have just water in there, if it dont play up then you know it was the coolent.
oops Classique71, already said that Razz[/edit]
[Updated on: Wed, 24 December 2003 11:04]
Re: MA61 engine problems..... Wed, 24 December 2003 11:56 Go to previous messageGo to next message
That frothyness in the radiator is from an additive that someone put in there to clean the block
I did this on mine, biggest mistake
I flushed it out with new distilled water about 5 times, didnt solve it, and then high pressure flushed it with a jerry-rig air compressor
Still didnt fix it
So my advice is to ingore it!
As for the backfire Ryley, have you checked the timing?
BlackSupra
Re: MA61 engine problems..... Wed, 24 December 2003 12:41 Go to previous messageGo to next message
Do 5ME's come equipped with a 'dashpot' like on the 5MGE??
This caused similar issues (backfiring wise) with my supra when i first got it. Just adjusted the dashpot contact point so upon deceleration it didnt backfire and act all cranky.
And clean the 10 cent piece sized airfilter too while your at it.
EDIT: To help you out Cool
http://www.geocities.com/ifli4u/EC_007.gif
[Updated on: Wed, 24 December 2003 12:44]
Evil_Foetus
Ballarat, Victoria
Re: MA61 engine problems..... Thu, 25 December 2003 13:41 Go to previous messageGo to next message
hmmm thanks guys.... ill take all this down Very Happy
edit: let me know when you're coming stu and ill make myself available Evil or Very Mad
[Updated on: Fri, 26 December 2003 01:52]
Allan
Re: MA61 engine problems..... Fri, 26 December 2003 12:18 Go to previous messageGo to next message
I would be more concerned the shit in your radiator is chemi-weld!
I would guess that would be why the #6 plug is looking crapy
If its the gasket on a 5m is can normaly be fixed for about $100 Smile trust me i know Very Happy
Allan
Evil_Foetus
Ballarat, Victoria
Re: MA61 engine problems..... Sat, 27 December 2003 12:06 Go to previous messageGo to next message
thanks alan....but erm....
whats chemi-weld? Razz Very Happy
Re: MA61 engine problems..... Sat, 27 December 2003 13:22 Go to previous messageGo to next message
Chemi-weld is a product that was designed so fill in cracks in a head, you pour it in the radiator, and presto, crack welded
But it has a habit of doing more than it should
Allan
Re: MA61 engine problems..... Sat, 27 December 2003 14:11 Go to previous messageGo to next message
or doing nothing at all Razz
Allan
Evil_Foetus
Ballarat, Victoria
Re: MA61 engine problems..... Thu, 08 January 2004 01:28 Go to previous message
hmmm...
we are going to take it to toyota and get the exhaust gas checked, and plug the ecu in or something, then go from there...
Surprised
Previous Topic:Best budget engine conversion on KE20?
Next Topic:Quad Throttel bodes
Current Time: Fri Nov 20 05:59:16 UTC 2026
Total time taken to generate the page: 0.010633945465088 seconds
