Toymods » Tech & Conversions » 1GGTE Temperature readings...
KiRK
1GGTE Temperature readings... Tue, 23 December 2003 23:55 Go to next message
Just curious what type of readings you guys are getting from your 1G's.
Mine seems to read on a scale a lot smaller than the gauge.
What I mean by this is from the cold marking to the 1/4 marking seems to be a 100% scale (1/4 meaning it's bloody hot).
Does this sound like my gauge is hooked up wrong? Or do I require a diiferent gauge / sender unit to get an accurate reading?
Cheers Kirk
dcving
newcastle nsw
Re: 1GGTE Temperature readings... Wed, 24 December 2003 02:31 Go to previous messageGo to next message
mine runs at about 150 degrees
KiRK
Re: 1GGTE Temperature readings... Wed, 24 December 2003 02:36 Go to previous messageGo to next message
And you've plugged it into the factory temp gauge... ?
Chris Davey
sunny coast, qld
Re: 1GGTE Temperature readings... Wed, 24 December 2003 02:48 Go to previous messageGo to next message
is that 150% water temp or what????
CrAiGzEE
south of the big smoke
Re: 1GGTE Temperature readings... Wed, 24 December 2003 03:21 Go to previous messageGo to next message
i think he is pulling ya leg
mine runs it boiling weather half way, sometimes just over going up a huge mountain
winter it runs at about a 3rd
in the celica manual its says normal opperating temp is between half and the next bar on the guage, anything over is to hot
KiRK
Re: 1GGTE Temperature readings... Wed, 24 December 2003 03:30 Go to previous messageGo to next message
So you guys are using the temp sender for the RA28? I think mine is plugged in the one form the 1G, prol why my gauge isn't accurate Sad
CrAiGzEE
Re: 1GGTE Temperature readings... Wed, 24 December 2003 03:39 Go to previous messageGo to next message
no i just plugged my old wire into the existing 1g sender
KiRK
Re: 1GGTE Temperature readings... Wed, 24 December 2003 03:49 Go to previous messageGo to next message
Thought you would say something like that Sad Now I've got to find what is wrong with mine.
Siktoy ra23
Plumpton/sydney
Re: 1GGTE Temperature readings... Wed, 24 December 2003 07:53 Go to previous messageGo to next message
Kirk
My temp guage is pluged in to the 1g factory sensor and my one reads about a third and even with a good thrassing it doesnt get over half way
Ben
KiRK
Re: 1GGTE Temperature readings... Wed, 24 December 2003 08:26 Go to previous messageGo to next message
Thanks for the replies guys... Think my gauge might be stuffed Sad
CrAiGzEE
Re: 1GGTE Temperature readings... Wed, 24 December 2003 11:02 Go to previous messageGo to next message
siktoy, mine used to be like that but i believe it has a blown HG now Sad
dcving
newcastle nsw
Re: 1GGTE Temperature readings... Wed, 24 December 2003 22:38 Go to previous messageGo to next message
sorry mine actually runs about 180 degrees thats farenhight though, thats off an autometer temp gauge
you cant expect an acurate reading off a gauge that only has hot and cold, it will only tell you if its getting hot or not, i mean it could be dangerously hot at half to three quarters, for example you just dont know, id personally get a real temp gauge
[Updated on: Wed, 24 December 2003 22:44]
Siktoy ra23
Plumpton/sydney
Re: 1GGTE Temperature readings... Thu, 25 December 2003 00:27 Go to previous messageGo to next message
kirk
What radiator are you running
BEN
KiRK
Re: 1GGTE Temperature readings... Thu, 25 December 2003 09:51 Go to previous messageGo to next message
It's a twin core of a st165 I think... It has the filler in the middle of the top tank.
Do you think something with better cooling properties is in order?
Cheers Kirk
Fattony
Re: 1GGTE Temperature readings... Fri, 26 December 2003 00:37 Go to previous messageGo to next message
mine runs at about 80-90 degrees never seem to have a problem, if you want to get accurate temp readings i hope u have not wired your dash temp guage into the 1g sensor, use the original sensor that the car come out with just for temp sensing for the gauge and the original 1g item for the comp.
gold28
Madrid - Spain
Re: 1GGTE Temperature readings... Fri, 26 December 2003 08:51 Go to previous messageGo to next message
I am not sure about the different versions of the 1G, but in my old GEN2 (I think thats what it was) I had to change the temp sender as it only hit about 1/3 when it was really hot. Putting in the original type sender fixed it. They do bolt in but if I recall correctly the 18R one is a bit longer and bottome out.
I am in the process of converting to a gen3 so I will let you know if the sender is any different.
Siktoy ra23
Plumpton/sydney
Re: 1GGTE Temperature readings... Sat, 27 December 2003 10:16 Go to previous message
I am running a twin core of a hg holden and I am having no trubles at all with only a 12" thermo
Ben
Previous Topic:Neg camber RCA's for xA6x
Next Topic:4AGE SQUEALING! under light acceleration?
Current Time: Mon Oct 26 17:41:26 UTC 2026
Total time taken to generate the page: 0.0065171718597412 seconds
