Toymods » Tech & Conversions » Car audio questions.
4AGE
Car audio questions. Wed, 24 December 2003 01:25 Go to next message
Hey guys. I just got myself some 6x9's from JB. Had them in my car for like 6 weeks or so. I remember there was a thread about running in voice coils e.t.c. And yes i did all that. They had tonnes of bass coz it would kinda echo off the hatch. Nowadays there is no bass. It sounds horrible. I used good cabling and connectors e.t.c. Anyone know what it can be?
BTW the Headunit is a Sony MX 630 if it helps....
Chris Davey
sunny coast, qld
Re: Car audio questions. Wed, 24 December 2003 01:36 Go to previous messageGo to next message
possibly, your ears have gotten used to it.
I know my stereo doesn't seem as loud as when i first put it in.
smt_007
Re: Car audio questions. Wed, 24 December 2003 01:37 Go to previous messageGo to next message
What brand are the 6x9's?, they cant get that bad so soon, maybe someone has been playing with your headunit settings.
4AGE
Re: Car audio questions. Wed, 24 December 2003 09:29 Go to previous messageGo to next message
Hmm dunno i have an ear for sound. And no i dont think i got used to it. Besides they distort now... i have no idea...
The brand of hte speakers are Cadence. They are some kinda exclusive for JB.
Re: Car audio questions. Wed, 24 December 2003 15:02 Go to previous messageGo to next message
How many hours did you run them in for?
The cheaper the speaker, the longer the run in time
clancey
Re: Car audio questions. Wed, 24 December 2003 23:07 Go to previous messageGo to next message
Have you got another set of speakers you could plug in to test the output from your head unit? Might not be a problem with the speakers.
Re: Car audio questions. Wed, 24 December 2003 23:37 Go to previous messageGo to next message
Hmm, maybe next time I see ya I can have a listen for you, I can usually pick these kinds of things (I study audio, remember)
mx83toy
Re: Car audio questions. Thu, 25 December 2003 02:14 Go to previous messageGo to next message
either your - and + wires are touching or the woofers are blown stick a multimeter on em and mesure the resistance let me know how you go
SupraBOY
Yeppoon/Rockhampton
Re: Car audio questions. Thu, 25 December 2003 02:21 Go to previous messageGo to next message
check that you haven't pressed the LOUD button on your HU.
Re: Car audio questions. Thu, 25 December 2003 13:06 Go to previous messageGo to next message
SupraBOY wrote on Thu, 25 December 2003 10:21
The LOUD button only works at low volume, the louder you turn the deck up, the less it does.
So I doubt this is it
And with older Alpine decks, when you use the preouts, the loud function does nothing, its disabled
T APLUS 22
Re: Car audio questions. Fri, 26 December 2003 09:11 Go to previous messageGo to next message
sounds to me like head unit settings for such a drop.
May sound silly, but are both speakers still working? Only having one running would have the effects you mentiond. This would account for the problem. btw where do you live? Round the frankston area? I can have a look if you like.
Decent speakers don't need a run in time. Proper testing is done by the manufacturers. Cadence are what I would call decent speakers. Imported from america, where they are pretty big. Better well known for they subwoofers, and high power amps.
There shouldn't be a gradual drop in performance like you mention as a result of not treating the speaker properly.
Hope I've helped. Which JB hifi Store did you buy them from? (I know the guys from the dandenong and frankston shops)
4AGE
Re: Car audio questions. Fri, 26 December 2003 13:02 Go to previous messageGo to next message
Well i kinda didn't really pump them. I ran them to a max of probably 40% of peak power. But even still they ran ok. I dunno it happened and deteriorated in a week or so. I have the loud feature on. But it ran fine always on loud feature. The woofers are still running ok. They still kicking but there aint bass! I've checked the connections at the speaker and its fine. Nothing touching. I fitted them myself n i've got it all insulated off with no excess wiring exposed. Well just in general. Speakers work fine out of the box. Run them in for about 5 hours or so... They should be fine yeah? They were usually 200 bucks a pair i picked them up for 160. So they are a midrange/high end 6x9.
Re: Car audio questions. Fri, 26 December 2003 13:35 Go to previous messageGo to next message
T APLUS 22 wrote on Fri, 26 December 2003 17:11
ALL speakers need run in time.
200 a pair is a mid/low range, but far from super low
200 a pair should still give out decent bass for at least a few years tho
Trace the wiring back to the back of the deck. If it is touching the body, or another wire somewhere, it will affect the output
Also make sure you have +ve and -ve around the right way, if its backwards, you get a heap of midrange, and no bass
Especially if one is correct, and one is backwards
4AGE
Re: Car audio questions. Sat, 27 December 2003 02:40 Go to previous messageGo to next message
Ah don't worry about it. I found the fault... My mistake. The speakers are fine. I had a look at it before. The center tweeters are shaped like this. (> (>. As in the center bit. The speakers use two large connectors not as the usual 1 big one small. I changed the direction of the speaker so the tweeters are like this (> <) so they look sik in my boot. So theoretically i'd have to reverse the polarity over. The wire did fall out of the connector a while ago and i think i put them back in incorrectly. Thanks for your help guys. I'll be writing a letter so they will use large/small connectors on their speakesr next time around. BTW is there any difference using 2 large connectors opposed to 1 large 1 small???
Re: Car audio questions. Sat, 27 December 2003 13:29 Go to previous messageGo to next message
Nah, some companies do one thing, some do another
Its wierd, but it stops idiots at home installing them, and trying to return them when they don't work.
T APLUS 22
Re: Car audio questions. Sun, 28 December 2003 08:18 Go to previous messageGo to next message
what makes you say that all speakers need run in time?
Re: Car audio questions. Sun, 28 December 2003 08:25 Go to previous messageGo to next message
and peewee - what the hell is that in your avatar?!
Re: Car audio questions. Sun, 28 December 2003 13:47 Go to previous messageGo to next message
TAPLUS 22
My boss tells me all speakers need run-in time. I can find out exactly why you need to run in speakers when he comes back from holidays, but I know it has something to do with stretching the rubber surround properly.
Try it yourself, crank up a NEW set of speakers, straight out of the box, with heaps of bass and see how much they distort.
And then try a set of the same speakers that have has 10-20hrs of medium run in, and see how much better they sound.
10 bucks says the second lot sound better.
But I'll find out the exact reason
And Greg, take a guess, what does it look like to you?
T APLUS 22
Re: Car audio questions. Sun, 28 December 2003 21:17 Go to previous messageGo to next message
ok, it is true that speakers sound better over time. However the 'Running In' of speakers is not actually neccesary. Warming up of speakers is a good idea, ie: don't start cranking them on a freezing cold morning, wait till movement as loosened the cone a little.
Cheers.
as for the avatar, who's finger is it? (was it)
Re: Car audio questions. Mon, 29 December 2003 01:56 Go to previous messageGo to next message
T APLUS 22 wrote on Mon, 29 December 2003 05:17
Mine
http://oz-enet.com.au/~peewee/andrew_2.jpg
Toobs
Re: Car audio questions. Mon, 29 December 2003 07:55 Go to previous messageGo to next message
Your system may start to distort if you used either thinner speaker cable than you should have or you did a Strathfield twist'n'tape installation (i.e. you didn't solder the wires)
And Cruzsida... you weren't working on an Excel or something when you injured your self like that... those damned things are the worst on your hands.
Re: Car audio questions. Mon, 29 December 2003 13:13 Go to previous messageGo to next message
Toobs wrote on Mon, 29 December 2003 15:55
You'd be surprised how many places employ the twist'n'tape method, more use it than don't
And no, not on an excel, on a ski rope
4AGE
Re: Car audio questions. Thu, 01 January 2004 11:31 Go to previous messageGo to next message
Ouch Fark! how did that happen i would like to know the whole story about your hand. I thought it was a damned good edit job.
It looks like theres a chalk outline of the hand as well. Like it was severed off. Mutilated and chalk outlined by the cops as evidence. Lol.
Yeah... Hmm my speakers pump harder after a while. They got a hell of alot more bass than they used to. I usually run in my speakers when i jump in the car... about 25% volume for a song approx 5 mins then i pump them
Re: Car audio questions. Tue, 06 January 2004 07:35 Go to previous message
4AGE wrote on Thu, 01 January 2004 19:31
Remind me later, I'll type it up
Previous Topic:lexus v8
Next Topic:How to pick a Blown Head Gasket 7M
Current Time: Fri Nov 20 08:45:53 UTC 2026
Total time taken to generate the page: 0.0072219371795654 seconds
