Toymods » Tech & Conversions » Engine Temps on mkIII's?
thug_immortal
Camden, NSW
Engine Temps on mkIII's? Wed, 24 December 2003 08:05 Go to next message
Does the mkIII supras engine bay seem excessivley hot after normal driving or is it just mine?
I think im gonna have to get me some decent fans or something cos its like a bloody oven in there Confused ne1 else have this prob or is it the same wid all ma70's?
V8_MA61
Re: Engine Temps on mkIII's? Wed, 24 December 2003 08:17 Go to previous messageGo to next message
i think its just the breed of the beast mate. best mod is to install a thermostat controlled fan, so it cools the water down to a certain temp even after the car is off. Other mod if you're real worried, and plan to keep the car, is to cut fins in the bonnet..like a ra23?
Blake.
dingaling
tas
Re: Engine Temps on mkIII's? Thu, 25 December 2003 02:27 Go to previous messageGo to next message
yeah i was wondering the same thing with my ma70.
I was worried how hot my engine bay was after driving it, but after awhile i've come to the conclusioin that these high performance engines just run really hot.
Still tho i wanted to be safe, so i wired up a button in the dash that turns the radiator fans on and off, without taking away the cars control of the fans. my digital dash temp gauge is always at the half way mark, sometimes one bar above, sometimes one bar below, so i just hope it's in the safe enough range.
AE82TwinCam
Canberra, ACT
Re: Engine Temps on mkIII's? Thu, 25 December 2003 05:21 Go to previous messageGo to next message
maybe you can also try putting a few spacers at back of your bonnet to raise it up a little bit and let some more air flow through.. I've read that this can lead to cabin temps going up a little bit but if you've got air con it shouldn't be a problem and if you don't, well you're going to be bloody hot anyway Smile
-Andrew
Re: Engine Temps on mkIII's? Thu, 25 December 2003 10:33 Go to previous messageGo to next message
Long as everythings working fine, your only options are to do things like ceramic coat the turbo, manifold and dump pipe, as well as install a big bonnet vent. Turbo engine bays are always hot after a good drive, and much worse is they're tight ones (e.g. Z32 300ZX)
SUPRAGTE
North Sydney
Re: Engine Temps on mkIII's? Thu, 25 December 2003 21:33 Go to previous messageGo to next message
Its the 7m mate. After a drive you can stand away from the car and its like a furnace, i'm worried about paint burning off!
I've ceramic coated turbo, manifold, exhaust wrapped dump pipe all the way to the cat double layered, wrapped intercooler pipes and everything else possible and it still doesn't help.
Coolant temps run between 86C(cool winter) up to 92C in summer on 40deg day, i read them through the micotech.
HedgehogSandwich
UK
Re: Engine Temps on mkIII's? Sat, 27 December 2003 16:29 Go to previous messageGo to next message
yep just a 'feature' of the engine.. you wannt see how hot the 1JZ gets !! makes the 7M seem cold.
You can try the aircon fan cooler mod, which helps in hot weather. details on sogi..
thug_immortal
Camden, NSW
Re: Engine Temps on mkIII's? Fri, 09 January 2004 02:59 Go to previous messageGo to next message
thanks guys,
im gonna try the thermostat and then try and think of a non hacking up the bonnet way to reduce temps, cant see it happening though hahaha.
Plans are on hold as i need to rebuild my bottom end :S, ah well... shit happens. Y is it always the cars we love cause us so much pain and cost us so much $$$?
Ah well, the joys of motorsport
SupraPete
Re: Engine Temps on mkIII's? Fri, 09 January 2004 03:32 Go to previous messageGo to next message
There is a strip of rubber at the bottom/back of the bonnet. Its only held on by little plastic pins.
Take the rubber off and more air escapes. Helped me.
Re: Engine Temps on mkIII's? Fri, 09 January 2004 04:20 Go to previous messageGo to next message
HKSPete wrote on Fri, 09 January 2004 11:32
Was that pre-uz days? or did u need it for the UZ?
HedgehogSandwich
UK
Re: Engine Temps on mkIII's? Fri, 09 January 2004 12:02 Go to previous messageGo to next message
seriously try the aircon fan mod.. they shift a LOT of air.
http://www.supras.com/04/resources/index.php?id=37 &q=fan
V8_MA61
Re: Engine Temps on mkIII's? Fri, 09 January 2004 12:13 Go to previous message
WHen im done making my exhaust side blow-by pipe ill give you some pics and explain what to do. It should make a big difference because of all the directed airflow past the headers
Will eventually make one for intake too, to stop heat-transfer
[Updated on: Fri, 09 January 2004 12:16]
Previous Topic:Help! Engine troubles
Next Topic:SR20 Brake Disks and Callipers on a AE-86?
Current Time: Mon Nov 2 18:13:18 UTC 2026
Total time taken to generate the page: 0.004767894744873 seconds
