Toymods » Tech & Conversions » 4ag head onto 4ac
hz383
4ag head onto 4ac Wed, 24 December 2003 09:36 Go to next message
I have just purchased a ae82 corolla with a 4ac engine. I would like to convert to a 4ag head using webers and was wondering what needs to be done to fit a 4ag head onto the 4ac bottem end. I have heard the blocks are the same, what about cam belt tensioners etc. where do I get a weber manifold, any info would be appreciated.
Steve-AE86
Ademelaide, SA
Re: 4ag head onto 4ac Wed, 24 December 2003 14:55 Go to previous messageGo to next message
you cant fit a 4age head to a 4ac block, and expect your pistons to last very long...
4ac pistons only have 2 valve cutouts.
4age pistons have 4.
the extra 2 valves per piston, will open, and probably hit the top of the 4ac piston, bend the valves, and probably do some sort of damage to the piston.
if you want 4age power in your ae82, then put a 4age in it.
hope that helps Cool
pro_ke
adelaide
Re: 4ag head onto 4ac Thu, 25 December 2003 00:55 Go to previous messageGo to next message
a 4AGE FWD motor should only cost about $300 anyhow so it is already a pretty cheap exercise
hz383
Re: 4ag head onto 4ac Thu, 25 December 2003 08:17 Go to previous message
thanks for the reply, i was just curious as I was told it was easy to do. piston change is no big hassle but, yeah just buy a 4age and carb would probably be easier and cheaper. Any one know where to get a carb manifold to suit?
Previous Topic:Help with gearbox swap
Next Topic:ST model dizzy
Current Time: Wed Oct 28 00:41:00 UTC 2026
Total time taken to generate the page: 0.023184061050415 seconds
