Toymods » Tech & Conversions » ECU pin outs
E30-323ti
ECU pin outs Wed, 31 July 2002 02:56 Go to next message
Can someone please confirm that the "Battery" pin on the attached pic is in the correct place, and it is a Black & yellow wire comming from the ECU plug. Soarer JZZ30 loom/ECU
The reason I ask is because I can't seem to find the other end in any of the plugs I have leftover (checking with the multimeter). Or does someone know were to find the power input to the loom?
Glenn
http://www.geocities.com/ggclhm1/ecupinouts.jpg
[Updated on: Wed, 31 July 2002 20:45]
E30-323ti
Re: ECU pin outs Wed, 31 July 2002 20:52 Go to previous messageGo to next message
Sorry if the pic doesn't come up here is the link http://www.geocities.com/ggclhm1/ecupinouts.jpg
Hopefully that works.
Anyway had another session with the multimeter last night and found some funny things (I think they're a bit weird), Are the findings usual.
The GROUND (near the battery in the pic) goes to one of the injector earths the other GROUND goes to the Map Sensor plug (that seems weird!)??
The O2 SENSOR is the terminal to the left of the A/T spd2 -ve.
I couldn't find where the RPM2 and SPEED terminal go.
Bloody wiring!!
Well that link didn't work either!! Am I just monkeying it up or is Geoshities not a very good place to link things to??
Glenn
[Updated on: Wed, 31 July 2002 20:55]
1G-GE KE35
Welly, NZ
Re: ECU pin outs Wed, 31 July 2002 22:30 Go to previous messageGo to next message
Glenn,
Try taking the www. out of the URLs, works for me!!
Sam
E30-323ti
Re: ECU pin outs Thu, 01 August 2002 00:19 Go to previous messageGo to next message
I did try that, Still the same!! F*#k ARSE thing!!
1G-GE KE35
Welly, NZ
Re: ECU pin outs Thu, 01 August 2002 00:33 Go to previous messageGo to next message
Geoshities is crap. If you go to the link and then take out the www. it will prolly work........
Re: ECU pin outs Thu, 01 August 2002 01:20 Go to previous messageGo to next message
Or cut and paste.
E30-323ti
Re: ECU pin outs Thu, 01 August 2002 03:32 Go to previous messageGo to next message
I think we are getting a bit Off topic here guys. Grin
Can anyone shed some light on the mysteries of wiring??
Glenn Rolling
BlakeNZ
Re: ECU pin outs Thu, 01 August 2002 07:34 Go to previous messageGo to next message
Sorry Glenn,I can't help with electrical advice.
However,I can offer some assistance to your bank balance if you were interested in copying your engine mounts for me,as I'm looking to do the same conversion as you.
With regard to ECU pinouts,do you mean "battery" as in the 'power' feed to the ECU?I have a few diagrams.
deesonet
Toowoomba
Re: ECU pin outs Thu, 01 August 2002 11:52 Go to previous messageGo to next message
Glenn
Yes, leave the www out and I can see the diagram.
I have 4 plug and 5 plug wiring diagrams for the 1JZ-GTE. It appears that the JZZ has a different version again. If my diagrams are any help I can send them.
E30-323ti
Re: ECU pin outs Thu, 01 August 2002 20:55 Go to previous message
Are all the wiring guru's on holiday at the moment?? Rolling
Previous Topic:Strange things have happened to my idle
Next Topic:Sensors on 18RGEU???
Current Time: Thu Nov 26 05:25:20 UTC 2026
Total time taken to generate the page: 0.0058720111846924 seconds
