Classifieds » Miscellaneous » FS: SUB(ficker) AND AMP(boss)
robbo84
adelaide
FS: SUB(ficker) AND AMP(boss) Wed, 31 July 2002 05:58 Go to next message
hey,
sellin my 12inch kicker sub and 800watt boss amp
the sub is in box as brought from shop
i still have the box the the amp came in when i brought it
make an reasonable offer for both or seperate
Guest
Re: FS: SUB(ficker) AND AMP(boss) Thu, 01 August 2002 07:07 Go to previous messageGo to next message
You got some specs for the amp ?
channels?
output?
specs?
approx price ?
Matt
robbo84
adelaide
Re: FS: SUB(ficker) AND AMP(boss) Thu, 01 August 2002 12:51 Go to previous message
here u go everything posible and lookin around
$500 for both but not to sure what there worth
but been told that $500 is pretty good
Full chrome chassis design
Bridgable power 2 Ohm stable
MOSFET DC-DC switching power supply
Low pass toroidal transformers
Variable Low Pass Filter (LPF: 40Hz ~ 250Hz at 12dB)
Variable High Pass Filter (HPF: 40Hz ~ 1kHz at 12dB)
Three step crossover switch
Super Bass Control (6dB, 12dB at 50Hz)
Auto fan cooling system
Adjustable gain control
Auto power on/off by remote
Frequency response at 10~40,000Hz
Protection circuit (overlock, thermal, short)
Line-out RCA jack
Specifications
4 ohm max. output @0.03% THD: 4 x 200W
4 ohm bridged output @0.02% THD: 2 x 400W
2 ohm WRMS output @0.1% THD: 4 x 200W
SNR 100dB
Stereo seperation: >55dB
Input sensitivity: 145mV - 2.4V
Input impedence: 10kohms
Operating Voltage: DC 12V
Speaker impedence: 4 ohms
Fuse rating: 20A x 2
Dimensions (WxHxD) mm: 320x53x263
Previous Topic:7mge?
Next Topic:Corolla 75-81 suspension
Current Time: Sat Nov 21 11:44:21 UTC 2026
Total time taken to generate the page: 0.0038459300994873 seconds
