Toymods » Tech & Conversions » sc14 troubles
Brenton_TA23
sc14 troubles Fri, 26 December 2003 10:05 Go to next message
Good evening all,
My mate is having trouble with his sc14. it whistles a bit when you get off the throttle. its inconsistent but generally whistles when you back off and the revs drop down. its fine under load. Its got me stumped, theres no apparent air leaks or nothing. any ideas would be helpful.
cheers guys.
hz383
Re: sc14 troubles Sat, 27 December 2003 02:56 Go to previous message
what is tha supercharger fitted to? If it is not a standard fit up check to see if the belt is slipping. had one doing the same thing on a g200 gemini, found that when i lifted the foot to deccel the belt would slip as the sc was still making boost but the engine didnt need it so it would try and stall the sc. the problem was fixed by fitting an over boost valve. if it is a standard fitment i can only suggest you check the over boost valve which will be on the intake plenum some where
Previous Topic:4AGZE from aw11 mr2 diffrences
Next Topic:Autronic and sensors
Current Time: Sun Nov 22 23:40:30 UTC 2026
Total time taken to generate the page: 0.007349967956543 seconds
