Toymods » Tech & Conversions » 4K mods?
HyDrA
Adelaide, SA
icon5.gif  4K mods? Sat, 27 December 2003 08:20 Go to next message
Hi all...
We have a KE70 with a nice little 4K-C in it. It's not a daily driver, just a thrashbox for now.
What are some popular mods for the 4K? I've heard a 3K head is popular (increased compression?)
What about a better carby?
Chris
Re: 4K mods? Sat, 27 December 2003 08:33 Go to previous messageGo to next message
ditch the stock air-cleaner, get some decent extractors and exhaust (1.75-2"). get a cam (camtech 609 is good for higher revs, but maybe the stage 3 one would be better for a daily thrashbox) then think about head porting (on a 3K head).
THEN start thinking about a bigger carb.
search for TOSCO manual on google. has all the specs for 3K race motors.
airfireman1
Perth WA
Re: 4K mods? Sat, 27 December 2003 10:02 Go to previous messageGo to next message
Yep, Extractors, Larger valves can be inserted think I fitted toyota crown type, double valve springs, a good cam grind, balance and linish the crank, A decent performance shop can match port the head and cc the combustion chambers. If you want to get carried away you can also get the block decked, go for a decent gasket set and a good set of rings.Redline do intake manifolds for either a single 45DCOE webber or twin 40 DCOE sidedrafts. All these are fairly standard mods. Ditch the mechanical fuel pump and go electric, you can also ditch the belt driven fan and go electric as in such a small motor every bit of power saved is power gained. Carried them out on my 1973 corolla back in the late seventies.
Now I'm showing my age.
Hope this gives you some ideas
HyDrA
Adelaide, SA
Re: 4K mods? Sun, 28 December 2003 00:33 Go to previous message
Thanks guys, i'll start asking around about the machining based mods, and start hunting around junk yards for some 3k and 4k's.
Previous Topic:last minute ma61 wiring question
Next Topic:AE71 STRUT SWAPS?
Current Time: Wed Oct 28 14:47:19 UTC 2026
Total time taken to generate the page: 0.049458980560303 seconds
