Toymods » General Car Talk » ne1 here work in a suspension shop
Mr DOHC
ne1 here work in a suspension shop Sun, 28 December 2003 02:27 Go to next message
i am looking to find out dimensions of certain shocks, does anyone here have those kind of details
Steve-AE86
Ademelaide, SA
Re: ne1 here work in a suspension shop Sun, 28 December 2003 03:25 Go to previous messageGo to next message
what details do you need...i just so happen to own a monroe shocker catalogue...which gives all dimensions from length, to width, stroke, etc..
if you want, tell me what you've got, and i'll tell you what will fit, or what will fit with spacers, etc.
wilbo666
Re: ne1 here work in a suspension shop Sun, 28 December 2003 04:11 Go to previous messageGo to next message
Steve-AE86 wrote on Sun, 28 December 2003 14:25
MA61 / SA63 (same?)
MX62
ST185
I would be very appreciative if you could give me all the measurements for the above! In particular the stroke of the MX62 units.
I have SA63 struts if you can recommend anything else that will fit them... Very Happy
Thanks heaps!
Mr DOHC
Re: ne1 here work in a suspension shop Sun, 28 December 2003 09:48 Go to previous messageGo to next message
dont worry, VK commodore rear shox fit, so they will b cheaper
Steve-AE86
Ademelaide, SA
Re: ne1 here work in a suspension shop Sun, 28 December 2003 23:32 Go to previous messageGo to next message
wilbo666 wrote on Sun, 28 December 2003 14:41
MA61 / SA63 (same?)
MX62
ST185
to start off, Type refers to this diagram:
http://www.users.bigpond.com/steveg101/shock%20types.jpg
Body is the length of the body,
Comp is the compressed length,
Extn is the extended length.
pretty easy, huh..
___________________
MA61
Type T6
Body 397
Comp 408
Extn 617
___________________
SA63/RA60
Type T6
Body 405
Comp 405
Extn 609
___________________
MX62 (9/80-8/82)
Type T5
Body 387
Comp 399
Extn 591
___________________
MX62 (9/80-7/84)
same as MA61
___________________
ST185
Type T6
Body 328
Comp 355
Extn 483
___________________
ok. believe it or not, ALL commodore, from 78-93 will fit SA63 struts, are exactly the right body length, and compressed length, but have 10mm less stroke.
wilbo666
Re: ne1 here work in a suspension shop Wed, 31 December 2003 01:42 Go to previous messageGo to next message
Thanks man! GREAT STUFF!
Can I ask you to look up another one for me.. AE92
Steve-AE86
Ademelaide, SA
Re: ne1 here work in a suspension shop Wed, 31 December 2003 09:55 Go to previous messageGo to next message
AE92
well here's the thing...
according to my 'monroe' application listing book... Rolling Eyes
you cant fit ae92 to your car, because they are a full strut replacement..not a cartridge.
as for stroke, etc...the book dont give any measurements for any struts.
sorry bloke. Rolling Eyes
steve
Jayem
Finland
Re: ne1 here work in a suspension shop Wed, 31 December 2003 10:52 Go to previous messageGo to next message
There are AE-92 with cartridges and with full strut shocks.
I have AE-92 cartridges made by Monroe in my Corona.
Re: ne1 here work in a suspension shop Thu, 01 January 2004 09:56 Go to previous messageGo to next message
Do you have details for RA28 inserts, just for a reference.
I'm trying to find something with an extended length of around 90mm less than the RA28 items.
Joel
Steve-AE86
Ademelaide, SA
Re: ne1 here work in a suspension shop Thu, 01 January 2004 11:07 Go to previous messageGo to next message
jayem, as i mentioned previously, the monroe book i have only mentions that the ae92 has complete struts, and there is no listing for a cartridge. i didn't say there is no such thing as a cartridge for them...it's possible that monroe has discontinued the inserts for them, and changed to just make struts?
RA28 has the same cartridges as the RA60, listed above.
with a 51mm spacer, you can use camira front inserts, or with a 64mm spacer, you can use ST-162 front inserts.
Re: ne1 here work in a suspension shop Thu, 01 January 2004 11:24 Go to previous messageGo to next message
would the st185 with a 40mm or so spacer be correct also?
Steve-AE86
Ademelaide, SA
Re: ne1 here work in a suspension shop Thu, 01 January 2004 11:33 Go to previous messageGo to next message
the stroke on the st185 is 128mm
the stroke on the ra28 is 204mm
to fit the st185 cartridges to your struts, you would need a 77mm spacer, as the body on the st185 cartridge is 328mm, and the body on the ra28 cartridge is 405mm, and the difference there is 77mm.
Re: ne1 here work in a suspension shop Mon, 05 January 2004 01:07 Go to previous messageGo to next message
I'm actually thinking of cutting the strut so I can keep suspension travel.
As my shocks currently are 90mm lower or so, i'd be looking for a shock with the extended length 90mm less than RA28 correct? Then cut the strut housing to suit?
Is there anything with extended length of around 520mm?
CHeers
Joel
wilbo666
Re: ne1 here work in a suspension shop Mon, 05 January 2004 02:09 Go to previous messageGo to next message
If you don't want to cut the strut you could use a spacer at the top to relocate the shock down, Like a big washer on top of the strut...
Purple_Beasty
New Zealand
Re: ne1 here work in a suspension shop Mon, 05 January 2004 04:10 Go to previous messageGo to next message
wilbo666 wrote on Mon, 05 January 2004 15:09
If you use a spacer at the top your suspension is likely to bottom out especially at 90mm.
Callum
Re: ne1 here work in a suspension shop Mon, 05 January 2004 04:24 Go to previous messageGo to next message
Yeah would prefer to shorten strut to retain suspension travel. I dont know what it is with RA28's but the front end is 90mm lower and its still quite high IMHO. If you look in the avatar thats 90mm lowered.
wilbo666
Re: ne1 here work in a suspension shop Fri, 16 January 2004 02:04 Go to previous messageGo to next message
Someone recently came up with VS commodore shocks (in another thread), can we get the specs on them as well Embarassed
Re: ne1 here work in a suspension shop Fri, 06 February 2004 01:18 Go to previous messageGo to next message
Does anyone have all the diamentions of the camira inserts? body length, extended length, stroke etc?
Thanks!
Joel
munki
Gold Coast
Re: ne1 here work in a suspension shop Fri, 06 February 2004 09:22 Go to previous messageGo to next message
i looked into these shocks for my celica but they dont seem to have the two notches cut out at the top of the shock rod to locate it into the strut top.
WOuld this be a big problem or could i just weld a washer onto the top and locate the shocks that way
Daniel
Steve-AE86
Ademelaide, SA
Re: ne1 here work in a suspension shop Fri, 06 February 2004 10:40 Go to previous messageGo to next message
toyota camry 3/83-86
type T6
Body 346
Comp 366
Extn 525
_______________________
VB-VP Commodore poo
type T6
Body 405
Comp 405
Extn 599
Camira
type T6
Body 354
Comp 354
Extn 504
SAAB 900
type T6
Body 348
Comp 368
Extn 522
sorry for not replying sooner... didn't get email notifications..hrmmm...
anyways..you cant use VR-VS fronts, cos they are complete struts.
steve
Re: ne1 here work in a suspension shop Fri, 06 February 2004 11:11 Go to previous messageGo to next message
Thanks mate!
Hmm I think camry sounds like the go!
[Updated on: Fri, 06 February 2004 11:11]
Steve-AE86
Ademelaide, SA
Re: ne1 here work in a suspension shop Fri, 06 February 2004 11:18 Go to previous messageGo to next message
np mate;)
Stefan
Hobart, Tas
Re: ne1 here work in a suspension shop Fri, 06 February 2004 12:55 Go to previous messageGo to next message
Steve-AE86 wrote on Thu, 01 January 2004 22:07
Hang on a bit, this sounds funny. I thought late Ra2x strut inserts (ie post 75 or 76, I'm not completely up with Ta2 & Ra2) were interchangeable with Ra6x, but were ~20mm shorter IIRC. I'm counting on this, 'cos I have some Ra2x konis waiting to go into the fronts of my ra65 along with some 30mm RCAs.
Are monroe doing somehting dodgy here?
Steve-AE86
Ademelaide, SA
Re: ne1 here work in a suspension shop Fri, 06 February 2004 13:14 Go to previous messageGo to next message
that's what the book says...same part number... Rolling Eyes
Megz
Re: ne1 here work in a suspension shop Sun, 15 February 2004 11:12 Go to previous messageGo to next message
So does anyone actually work in a suspension shop in sydney this could help me too?
Megz
Jayem
Finland
Re: ne1 here work in a suspension shop Mon, 16 February 2004 14:48 Go to previous messageGo to next message
Quote:
SAAB 900
type T6
Body 348
Comp 368
Extn 522
WRONG!
Saab 900 shocks are like RWD Toyota rear ones (eye bottom and pin top).
bbaacchhyy
Re: ne1 here work in a suspension shop Tue, 17 February 2004 02:31 Go to previous messageGo to next message
Can you please provide me with the specs on th RAV4 rear, and MA70 rears please
Michael B
Re: ne1 here work in a suspension shop Thu, 22 September 2005 00:59 Go to previous messageGo to next message
Sorry to dig up such an old thread.. But does anyone know the length, diamentions etc of a GH sigma front shock?
need to find something to replace it that is around 60 mm shorter.
thanks!
Joel
Stefan
Hobart, Tas
Re: ne1 here work in a suspension shop Thu, 22 September 2005 02:37 Go to previous messageGo to next message
Try the online catalogs & pdfs on the monroe site - you can look up what you have, get it's part #, then compare it's dimensions/extendedlength/compressedlength with others.
Re: ne1 here work in a suspension shop Thu, 22 September 2005 02:40 Go to previous messageGo to next message
Damn I checked Monroe's site and found some online catalog but only part numbers, no diamentions. But if you say its there i'll keep hunting!
Stefan
Hobart, Tas
Re: ne1 here work in a suspension shop Thu, 22 September 2005 03:05 Go to previous message
http://www.monroe.com/catalog_lookup/ocl_miscappin fo.asp
Here you go. I did a similar thing a while ago. IIRC, you have to use the online part # search that you already found to get the part # for your current damper, then find out what sort of type it is. Then you can download the .pdf and reference appropriate substitutes (and then have to plug the part # back in to see what car it is for). Hope this helps.
Previous Topic:any info on an MR2 wanted please
Next Topic:No headlights, can you drive during the day?
Current Time: Fri Nov 20 06:30:10 UTC 2026
Total time taken to generate the page: 0.012385129928589 seconds
