Toymods » Tech & Conversions » 2TG cam specs
BigBadBenny
Brisbane, Queensland
2TG cam specs Sun, 28 December 2003 05:57 Go to next message
Cam someone give me a run down on what the numbers mean on the cams in the 2TG motor.
I'm slightly confused now after recieving a 2TG head that in theory had the cams around the wrong way (printed 1 and 2 respectivly) but the lobes said that it was right.
Benny
BigBadBenny
Re: 2TG cam specs Tue, 30 December 2003 10:46 Go to previous messageGo to next message
bump
ta2272
Re: 2TG cam specs Tue, 30 December 2003 13:56 Go to previous messageGo to next message
i can take a pic of mine with witch side is witch if this is any help
Jason
BigBadBenny
Re: 2TG cam specs Wed, 31 December 2003 00:32 Go to previous messageGo to next message
thanks for the offer Jason,
But I'm after cam specs more,
I cleaned up the cams and found other numbers that make more sence to me.
So can anyone give me a run done on the cam specs of 2TG motors?
thetoyman75
Club President
Re: 2TG cam specs Wed, 31 December 2003 08:46 Go to previous message
Benny,
The only 2TG cam specs I have are these:
2T-G Engine modifications as per April 1973 were from Engine Number 2T-8038333
Firing Order: 1-3-4-2
Ignition Timing: 16 Degrees BTDC / 800 rpm
Compression ratio: 9.8:1
Bore and Stroke: 85.0 x 70.0
Valve Size: Intake – 43mm (Up to April 1973)
– 44.5mm (April 1973 Onwards)
Exhaust – 37mm (Up to April 1973)
– 38.5mm (April 1973 Onwards)
Cam Shaft: Lobe Height In 45.87 ~ 45.97 (Up to April 1973)
Lobe Height In 46.37 ~ 46.47 (April 1973 Onwards)
Lobe Height Ex 45.87 ~ 45.97 (Up to April 1973)
Lobe Height Ex 46.37 ~ 46.47 (April 1973 Onwards)
Cam Lift: In 9.82 (Up to April 1973)
In 10.27 (April 1973 Onwards)
Thats the specs for the 88220 and 88222 Cams. Shame they don't lift Cam Duration.
Ex 9.82 (Up to April 1973)
Ex 10.27 (April 1973 Onwards)
[Updated on: Wed, 31 December 2003 08:51]
Previous Topic:Exhaust Flange Gasket job.... worried!
Next Topic:Wilwood Calipers road legal?
Current Time: Sat Oct 24 04:38:07 UTC 2026
Total time taken to generate the page: 0.0044867992401123 seconds
