Toymods » Tech & Conversions » Oil light is coming on... (7M-GTE)
ViNcEnXo
Oil light is coming on... (7M-GTE) Mon, 29 December 2003 05:04 Go to next message
I was driving along and the oil light came on, so I pulled over, checked the oil, it's fine... shined a torch in the oil cap, and have good oil flow...
What do I need to do? Best to get a guage on it to make sure it's got oil pressure, could it be the sensor?
What do you guys think is going on?
Paul
punkdefender
Dandenong/VIC
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 06:02 Go to previous messageGo to next message
have you run a ecu diagnostic test?
ViNcEnXo
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 06:50 Go to previous messageGo to next message
No, how do I do that?
punkdefender
Dandenong/VIC
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 07:15 Go to previous messageGo to next message
Check this url...
http://members.optushome.com.au/sajeewaw/diagnosti cs.htm
This how I did it in my soarer, I think the 7m would be the same...
ViNcEnXo
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 07:33 Go to previous messageGo to next message
blink blink blink blink blink blink blink.....
You get the idea, it showed normal.
M.J.H
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 08:06 Go to previous messageGo to next message
Could be a dodgy sender unit but put a pressure guage on it first or just hook up an aftermarket one somewhere permanatly.
ViNcEnXo
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 08:11 Go to previous messageGo to next message
Where do I put the new guage on?
ViNcEnXo
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 08:12 Go to previous messageGo to next message
As in, where do I plumb it into?
Paul
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 08:30 Go to previous messageGo to next message
you'd replace the idiot light sender switch with a sender that shows actual pressure.. the VDO pressure senders i have are all 1/8 NPT thread. the K motor idiot light sender was a smaller thread diameter, but very similar thread, so i just used a 1/8 NPT tap to open it up a bit Very Happy
ViNcEnXo
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 08:40 Go to previous messageGo to next message
I just went and switched the car on and it didn't come up......
It could do with an oil and filter change, I don't think the mechanic flushed out the system when he did all the work on it so it's probably full of crap!
I am sure that's all that is needed *touch wood*
Manny
Re: Oil light is coming on... (7M-GTE) Mon, 29 December 2003 13:07 Go to previous messageGo to next message
Don't know about the older Soarers, but the MKIII Soarers have both oil pressure and oil level warning lights. I had a faulty oil level sensor which kept giving me false warnings even though the oil was up to the full level. I swapped out the sensor for a know good one and no more warnings unless the oil is genuinely low.
ViNcEnXo
Re: Oil light is coming on... (7M-GTE) Wed, 31 December 2003 00:07 Go to previous messageGo to next message
I wanna replace the sensor...
How do I get it out? Where is it?
ViNcEnXo
Re: Oil light is coming on... (7M-GTE) Wed, 31 December 2003 00:30 Go to previous messageGo to next message
And where do I plump a guage into?
Allan
Re: Oil light is coming on... (7M-GTE) Thu, 01 January 2004 08:02 Go to previous message
next to the oil feed for the turbo on the block from memory... dont snap it off, did that on an m-eu and ended up discarding the motor (wasnt a hard choice with a free 5m-e to replace it)
Allan
Previous Topic:odd locker noises
Next Topic:Looking for JZA70 GA70 MA70 A/C amp (controll box thingy)
Current Time: Sun Oct 25 21:27:33 UTC 2026
Total time taken to generate the page: 0.0049099922180176 seconds
