Toymods » Tech & Conversions » legals on lowering engines.
people100
Rocklea qld
legals on lowering engines. Mon, 29 December 2003 07:19 Go to next message
i have a ta23 that im putting a 18rgeu in. ive rushed in and lowered the engine about 25mm on the mounts but am now sitting back and thinking is it legal. Looking at the crossmember you cant physically see that it has been modified so will they know and is it legal to do.
Mad RS
Nerang, QLD
Re: legals on lowering engines. Mon, 29 December 2003 07:49 Go to previous messageGo to next message
When I was researching lowering the engine in a escort the responce I got was, "So long as nothing is closer than 100mm to the ground then it is fine". Not sure if it is correct but so long as nothing fowles the crossmember and the sump is in no danger of being hit then all should be fine.
Re: legals on lowering engines. Mon, 29 December 2003 08:34 Go to previous messageGo to next message
as long as you have ground clearance and Xmm between any part of the engine and any thing not part of the engine (ie chassis, crossmember, steering etc) then will be fine. check with an engineer as to what X is.
Lambolica
Northwestern Sydney
Re: legals on lowering engines. Tue, 30 December 2003 07:21 Go to previous message
I think X is 15mm
Previous Topic:R154 rebuild
Next Topic:AE92 Brake help
Current Time: Mon Oct 26 13:29:32 UTC 2026
Total time taken to generate the page: 0.018460988998413 seconds
