Toymods » Tech & Conversions » bitsa 4agte question (coils/igniter/afm)
TraeKe86
Perth, W.A
bitsa 4agte question (coils/igniter/afm) Mon, 29 December 2003 15:31 Go to next message
Hey guys, I have a 4agze engine, basically just finalising a few things on it now, I need to buy coils and an igniter module for it, but I am pretty confused now with what I actually need, My engine is mr2 bottom end and Levin top, My wiring loom is Map, but my computer is Afm..
i have only seen the map sensored ze's and they had 2 coils with 2 connections on each with 1 igniter, A toyota mechanic friend of mine said that the afm ze's need only 1 coil, and have 1 igniter..
basically what i need to know is, how many coils do i need, and just the one igniter?
its a ae92 (1989) model engine (well.. the top half anyways)
and, did the gze's ever come with afm's? or am i just way of base.. i have a diagram of the ecu which has afm stuff on it but the wiring loom doesnt have any afm stuff on it, but it has map..
and i cant afford a aftermarket ecu.. :/
-bc
DAMO
MELBOURNE
Re: bitsa 4agte question (coils/igniter/afm) Mon, 29 December 2003 17:44 Go to previous messageGo to next message
I had a gze with afm and twin coils. I think the early mr2's had afm and a distributor and one coil. Which computer do you have as this will determine which way to go. Hope this helps.
feral4mr2
Bundaberg, Qld.
Re: bitsa 4agte question (coils/igniter/afm) Mon, 29 December 2003 21:02 Go to previous messageGo to next message
Freak yeah the aw11 gze has a dizzy, single coil and AFM.
i have a friend that bought a Levin 1/2 cut, that had a CAS, twin coil and AFM.
Gremlin
Maroubra
Re: bitsa 4agte question (coils/igniter/afm) Tue, 30 December 2003 00:00 Go to previous messageGo to next message
my gze has dual coils and afm... they are out there
TraeKe86
Perth, W.A
Re: bitsa 4agte question (coils/igniter/afm) Tue, 30 December 2003 13:18 Go to previous messageGo to next message
Thanks for the info guys, I had a look for coil packs and an igniter, couldnt find an igniter anywhere (althou coventries didnt stock them they had the price listed at 667$. Ouch!) The mate thats helping me build the car (alot) managed to get intouch with a guy thats gonna swap the cas for a dizzy, So i dont have to get an igniter, and I from there I can just buy a generic Coil pack, Should work out fine Smile
thanks again
-bc
DAMO
MELBOURNE
Re: bitsa 4agte question (coils/igniter/afm) Tue, 30 December 2003 18:22 Go to previous messageGo to next message
If your ecu is for twin coils I dont think the setup you have mentioned will work.
Re: bitsa 4agte question (coils/igniter/afm) Tue, 30 December 2003 21:37 Go to previous messageGo to next message
Well I've got a pair of GZE DFI coils if you need em Evil or Very Mad You should be able to use the 'normal' metal can type igniters that come on many toyotas (e.g. camry's) - an igniter is, after all, just a transistor, and technically only worth a couple of dollars at the most! If your engine has a crank angle sensor and not a dizzy, then you definately need the coils. Only the old scholl (mainly AW11) GZE's used a dizzy, and if your's is MAP sensed, then you definately need multi coils. Also, if it's a small port/higher comp GZE, it's definately a 'later' one! Evil or Very Mad
Adsport
Perth WA
Re: bitsa 4agte question (coils/igniter/afm) Wed, 07 January 2004 08:41 Go to previous messageGo to next message
mrshin i think we need the coils. im the guy doing all the work.
sideshow
Re: bitsa 4agte question (coils/igniter/afm) Wed, 07 January 2004 09:33 Go to previous messageGo to next message
yr best way out of it is to get a matchin electrical set
get an ecu with matchin coils and dizzy
tryin to get bits from here and there u might get wrong parts
and when u come to diagnosis problems u just run round in circles
there are
map ecu 4agze both have twin coil setup
there are 2 types of map ecus one is very hard to find
there is an air flow ecu form a corolla
and an airflow ecu from an mr2
so u need all the matching parts to suit the ecu
i know that some ignitors are not interchangable in toyotas
but u can use a 7mgte ignitor on a twin coil 4agze
i know u say u cant afford an aftermarket ecu
but doin it this way
make sure u get the right parts
otherwise it might cost more in the long run
even a 2nd hand microtech sells for 500 or less
maybe savin for 2 more months and gettin an ecu will save you headaches
just from past experience with conversions
gettin bits from 5 different places always stuffs things round
TraeKe86
Perth, W.A
Re: bitsa 4agte question (coils/igniter/afm) Fri, 09 January 2004 01:01 Go to previous message
yer i might have to save up for a little while for a second hand aftermarket computer, just means my cars not gonna run for a little while more now Sad oh well, at least it will run, I hope :/
thanks for all your help guys, Smile
-bc
Previous Topic:Replacement Panel Filter vs POD's
Next Topic:air intakes
Current Time: Fri Nov 20 08:45:46 UTC 2026
Total time taken to generate the page: 0.0071580410003662 seconds
