Toymods » Tech & Conversions » sanding heat cure paints back?
sanding heat cure paints back? Tue, 30 December 2003 03:24 Go to next message
I've just painted my water pump pulley (thanks Dave), and it's come out a little lumpy (which wasn't suprising, considering the poor quality of undercoat I gave it)
now while I realise it's only a pulley, I'm a bit of a perfectionist, so I'm wondering if you can sand back heat cured paints before they're been heat cured? it's thoroughly dried, but says it will cure under normal engine operating temps (which would be great, if it was in a car)
Allan
Re: sanding heat cure paints back? Tue, 30 December 2003 03:34 Go to previous messageGo to next message
bake it in an oven
Re: sanding heat cure paints back? Tue, 30 December 2003 04:05 Go to previous messageGo to next message
I prefer my food non paint-smelling Razz
my driveway typically gets to around 70+ degrees on a hot day, so I might just leave it there
FKN16V
NSW, East Coast
Re: sanding heat cure paints back? Tue, 30 December 2003 10:54 Go to previous messageGo to next message
Stick it in direct sun on a hot day for at least 3hrs, that should do it.
I did that with my cam covers and it worked a treat.
Steve
Re: sanding heat cure paints back? Tue, 30 December 2003 12:40 Go to previous messageGo to next message
yeah, did that today
was hot enough that I couldn't pick it up for more than a few seconds, so I think that would've done it Smile
allencr
tallahassee FL usOFa
Re: sanding heat cure paints back? Tue, 30 December 2003 13:18 Go to previous message
sand away.
paint requiring it be cured by heat requires a lot more then under hood temps or sitting in the sun at the equator.
i think the stuff on the can about curing is only about speeding up its drying process and is mostly advertising bs to lead you to believe that the paint is some how "baked" on and a better product then it really is.
Previous Topic:new motor in ta22, few probs
Next Topic:who's done the 2TGZEU ?
Current Time: Tue Oct 27 18:14:00 UTC 2026
Total time taken to generate the page: 0.044206142425537 seconds
