Toymods » Tech & Conversions » Octane Booster????
GIN51E
Berowra-Sydney
Octane Booster???? Wed, 31 July 2002 10:19 Go to next message
I know this might sound like a stupid idea and i have no idea weather it would work at all but its just one of those stupid inventions that popped into my head.
ok now say you got a bottle, filled it up with Octane Booster and connected it between the carb and fuel pump. and had a electronic valve attached so at a press of a button you got a burst of almost pure octane booster (would be slightly diluted with fuel) pumped into the engine, would this give you a sudden increase in engine power? or will an engine only run on octane booster if its mixed within fuel?
anyway just an idea, hehehe
Guest
Re: Octane Booster???? Wed, 31 July 2002 11:04 Go to previous messageGo to next message
NO
GIN51E
Berowra-Sydney
Re: Octane Booster???? Wed, 31 July 2002 11:09 Go to previous messageGo to next message
What's no ment to mean? are you going to at least explain why? as i don't know the chemistry of Octane Booster so would someone be able to explain to me with confidense why this wouldn't work.
Re: Octane Booster???? Wed, 31 July 2002 11:12 Go to previous messageGo to next message
The only advantage you are going to get with higher octane is if it is tuned for it.
If you gave it a sudden hit and were able to give it a big dose of ignition timing or something simultaneously, you might achieve something...hardly worth the effort though.
Guest
Re: Octane Booster???? Wed, 31 July 2002 11:22 Go to previous messageGo to next message
If a dilute mixture of comercial octane booster will clog and trash a set of plugs after only a couple of tanks, imagine what a concentrated dose would do.
COntrary to popular belief , octane booster does not actually make the fuel more explosive or volatile in fact it does the opposite.
Shit fuel goes bang too easy !!
the correct dose of octane booster will lower volatility enough to reduce/ control detonation by promoting even controlled burn at the correct time in the combustion cycle.
any more will lower power. and stuff plugs
Matt
GIN51E
Berowra-Sydney
Re: Octane Booster???? Wed, 31 July 2002 11:32 Go to previous messageGo to next message
ok that all makes sense, so whats the deal with NOS is that just simply a highly explosive material?
Guest
Re: Octane Booster???? Wed, 31 July 2002 11:36 Go to previous messageGo to next message
No NOS introduces additional oxygen into your intake air which allows more fuel to be burnt at the correct a/f ratio allowing more power to be made.
a side benefit is the intercooling effect of the high pressure gas entering the inlet.
Matt
Apollo
Brisbane, QLD, Australia
Re: Octane Booster???? Wed, 31 July 2002 11:37 Go to previous messageGo to next message
All NOS does is give it a shot of nitrous oxide which is just a shot of pure oxygen.
More oxygen, more fuel burnt, less fuel/air ratio, leaner mixture = stuffed engine.
Basically turbo without larger injectors in a can.
GIN51E
Berowra-Sydney
Re: Octane Booster???? Wed, 31 July 2002 11:40 Go to previous messageGo to next message
alrighty then, so say avgas isn't more explosive but just more stable thats why an engine runs better on it?
Guest
Re: Octane Booster???? Wed, 31 July 2002 11:44 Go to previous messageGo to next message
Avgas resists detonation better than standard fuel.
the power advantage would only come after appropriate tuning , unless your engine was already starting to detonate.
Matt
GIN51E
Berowra-Sydney
Re: Octane Booster???? Wed, 31 July 2002 11:48 Go to previous messageGo to next message
oh ok well thanks for that i'm now a smarter man. Very Happy
Stefan
Hobart, Tas
Re: Octane Booster???? Wed, 31 July 2002 13:34 Go to previous messageGo to next message
It's worth adding here that the higher octane a fuel, the less energy (and therefore power) it actually has. Just prevents pinging.
Guest
Re: Octane Booster???? Wed, 31 July 2002 22:15 Go to previous messageGo to next message
True, however the power gains made by increased compression or boost as well as ign timeing advance far outstrips the loss through less "powerful" fuel.
I think if we could calculate the % of energy actually harnessed in an internal combustion engine we would all be disapointed.
I cant remember off teh top of my head, does anyone remember the efficiencies of the carnot cycle ??
Matt
AE82TwinCam
Canberra, ACT
Re: Octane Booster???? Thu, 01 August 2002 00:14 Go to previous messageGo to next message
I think I remember the thermal efficiency of engines these days is like 10-20% or something, but don't quote me on that, it may be lower, but it certainly isn't very good Cry
-Andrew
Guest
Re: Octane Booster???? Thu, 01 August 2002 00:53 Go to previous messageGo to next message
I might have to revise some thermodynamics and work it out again.
matt
Apollo
Re: Octane Booster???? Thu, 01 August 2002 11:16 Go to previous messageGo to next message
I'm pretty sure an internal combustion engine is only 20% efficent.
I remember 20% efficency from somewhere a long time ago.
Z1Soarer
Townsville
Re: Octane Booster???? Thu, 01 August 2002 11:24 Go to previous messageGo to next message
I havent done any thermodynamics for a couple years either now, but I'm pretty sure combustion engines anywhere between 5-25% efficient (or so)
which is pretty piss poor!
ed_ma61
Lost in the K hole
Re: Octane Booster???? Thu, 01 August 2002 12:05 Go to previous message
thermodynamics is such a long long way away in my head these days... but i do remember the carnot cycle of heat engines:
and i quote:
The Carnot cycle is a four step process involving two isothermal processes (which are said to be ideal reversible processes) at the temperatures Th and Tc and two adiabatic processes (ie, without heat transfer) which operate between those two temperatures. In the isothermal steps, there is no change in internal energy and the heat exchanged is equal to the work done. In the two adiabatic processes, there is no heat exchanged. No such system can ever be built - since it is an idealized process (the two isothermal steps being reversible and quasistatic which means, in effect, they occur infinitely slowly). The importance of the process is that it gives an upper limit to the efficiency of any cyclic process between the same two temperatures.
be damned if i can remember what that upper limit is tho wrt interal combustion engines.
also wrt the original post question, what your suggesting has basically been done with water/methanol injectors: used to prevent detonation at high boost levels, or to run higher compression in engines not otherwise designed to do so. methanol has a ron of about 112 or 115, + cools the intake charge, and the water helps lower combustion temp, also reducung detonation.
so, yes, you can use an injected octane booster (in conjunction with other strategies) to produce more power, not quite how you anticipated i suspect though Rolling
ed
Previous Topic:1jz-GTE into an R30 skyline
Next Topic:A-GE 16 or 20 valve???
Current Time: Fri Oct 23 19:23:59 UTC 2026
Total time taken to generate the page: 0.0053689479827881 seconds
