Toymods » Tech & Conversions » 1JZ Twin Dump Overboost Correction
wastegate
Gold Coast
1JZ Twin Dump Overboost Correction Tue, 30 December 2003 22:51 Go to next message
Well, I take back all the information about the overboosting on my 1JZGTE. What I said was wrong and incorrect. I've solved the problem.
Fuel Filter..
DON'T GET MONKEYS TO SERVICE YOUR CAR!
I got a service done awhile ago that included changing the fuel filter.
They put in the wrong filter (from a mk2 by the looks) and also hooked it up backwards!!
Seems over time the Walbro pump half collasped the filter element and blocked fuel. The engine was running lean causing EGT's to sky rocket causing the turbos to overspeed.
All I can say is I was wonderfully wrong!
I'll be putting it on the dyno soon to see what twin dumps, bar&plate cooler and 0.9bar does. WOOT
Re: 1JZ Twin Dump Overboost Correction Tue, 30 December 2003 23:00 Go to previous messageGo to next message
So was it the fuel filter that was causing your car to not run?
wastegate
Gold Coast
Re: 1JZ Twin Dump Overboost Correction Tue, 30 December 2003 23:55 Go to previous messageGo to next message
Yup, I'd say it collasped more and just didn't have fuel pessure for it to run. Lucky..
Re: 1JZ Twin Dump Overboost Correction Wed, 31 December 2003 01:26 Go to previous messageGo to next message
You should do what I do, and run no fuel filter at all! Shocked
Or even better, never ever send your pride and joy to a mechanic again. I wouldn't take the risk with mine.
wastegate
Gold Coast
Re: 1JZ Twin Dump Overboost Correction Wed, 31 December 2003 01:30 Go to previous messageGo to next message
Norbie, when I took out my Walbro you should have seen the shit in the filter on the bottom... holy shatnaz! I need to goto PetroJet and get another filter! I'll show you next time you are down.
Re: 1JZ Twin Dump Overboost Correction Wed, 31 December 2003 01:38 Go to previous messageGo to next message
OK, so maybe I should install a filter one day...
Re: 1JZ Twin Dump Overboost Correction Wed, 31 December 2003 02:00 Go to previous messageGo to next message
Is there any way to run a strainer type filter on your in tank pumps? Something like a 100 micron one?
wastegate
Gold Coast
Re: 1JZ Twin Dump Overboost Correction Wed, 31 December 2003 02:11 Go to previous messageGo to next message
not sure what you mean, my Walbro has it's own filter, seems VERY filtery! Very Happy
Chris Davey
sunny coast, qld
Re: 1JZ Twin Dump Overboost Correction Wed, 31 December 2003 03:13 Go to previous messageGo to next message
Sounds good mate.
So you would recommend the twin dump pipe upgrade to people who are after 250rwkw or less now?
jzz30
Re: 1JZ Twin Dump Overboost Correction Sat, 03 January 2004 02:50 Go to previous messageGo to next message
i'm interested to see your results, my twin dump pipes are going on soon, and running a very similar set up (except more boost from CT9 steel ex. wheels) and A340E transmission..
good luck!
Allan
Re: 1JZ Twin Dump Overboost Correction Sat, 03 January 2004 03:05 Go to previous messageGo to next message
Norbie wrote on Wed, 31 December 2003 12:26
VERY BAD no love from your injectors!
Now that is a good idea! i dont trust anyone sence i had an auto fitted without loctite on the drive plate bolts Sad
recently i trusted a well known race suspension place to fit my lower controll arm bushes (as i dont yet have a press) crawled under it the other day and noticed split pin missing from the RH lower baljoint! it only takes one little thing to cause a major fuck-up
Allan
supra1jz
Launceston, Tasmania
Re: 1JZ Twin Dump Overboost Correction Sat, 03 January 2004 05:02 Go to previous message
jzz30: How much did the exhaust wheel upgrade cost???? I've blown one of my ct12a's and I'm putting another one on but I'd like to put steel exh. wheels on as well. Are they hard to come by?? What about spool up time is that the same?? Compressor upgrade?? Grrrrrr. I'm keeping the ct12's because I like the minimal spool up time etc.
Rich
Previous Topic:4K twin SU setup
Next Topic:brake recondition
Current Time: Mon Oct 19 13:46:39 UTC 2026
Total time taken to generate the page: 0.03909707069397 seconds
