Toymods » Tech & Conversions » Brake Light!! Help!!!
Malicia
icon4.gif  Brake Light!! Help!!! Wed, 31 July 2002 11:34 Go to next message
After replacing the bulbs for the brake lights I have noticed that now when the parkers/headlights are on the brake lights don't turn off!! But when the parkers/headlights are off they work fine??
Anyone got any ideas as to why?
[Updated on: Wed, 31 July 2002 11:35]
Malicia
Re: Brake Light!! Help!!! Wed, 31 July 2002 11:49 Go to previous messageGo to next message
Also just noticed not sure if this is spose to happen but i can't remember it doing this b4........ If the parkers are off when the brake is pressed they turn on along with the dash lights.
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: Brake Light!! Help!!! Wed, 31 July 2002 11:57 Go to previous messageGo to next message
are the globes the one's with tail and brake ??
sounds like the globe is in the wrong way. pull them out and put them in with the contacts the opisite to how they are now.( i hope i made sense, bit tired)
???? worth a try.
Malicia
Re: Brake Light!! Help!!! Wed, 31 July 2002 12:05 Go to previous messageGo to next message
yeah they are in the right way, the little nobby bits that hold it in are lope sided so it only goes in one way.
Argh!! If you fix one thing something else goes wrong!!!
Malicia
Re: Brake Light!! Help!!! Wed, 31 July 2002 12:08 Go to previous messageGo to next message
hmmmm don't spose it would matter what side they go in would it??
.......back out into the cold......
feral4mr2
Bundaberg, Qld.
Re: Brake Light!! Help!!! Wed, 31 July 2002 12:14 Go to previous messageGo to next message
just sounds to me, that when you turn you dash lights/parkers on the brake light comes on(bright), when you turn them off and press the brake i rekon the tail light is actually comming on(not as bright). if the light is brighter when the dash/parkers are turned on than when you just push on the brake pedal, then they are the wrong way about. dont know how this would occur with the lugs stopping them from going in the wrong way, but to me it is what it sound like is going on.????
Malicia
Re: Brake Light!! Help!!! Wed, 31 July 2002 12:15 Go to previous messageGo to next message
Embarassed Embarassed I spose it dose matter seems swapping them fixed it Embarassed
pedroenglish
icon14.gif  Re: Brake Light!! Help!!! Wed, 31 July 2002 13:33 Go to previous message
This is a classic bad earthing/grounding symptom, with unwanted coupling of circuits through filaments of combo-bulbs.Because its not a direct circuit, lamps are usually not full brightness.
Pedro
Previous Topic:AE86 Suspension advice
Next Topic:conversion-supercharging
Current Time: Thu Nov 19 12:01:10 UTC 2026
Total time taken to generate the page: 0.040807962417603 seconds
