Toymods » Tech & Conversions » 4age engine stand bolts
natez
4age engine stand bolts Thu, 01 January 2004 08:53 Go to next message
Hey
Needa get my 4age ready to put in my ae86,
went to put it on the stand, and i need some bolts, i've got 10m and 12m bolts, but it looks like i need 11mm, i cant find them anywhere... or do i need some other sizing bolts, i'm not familiar with the 3/8th sizing system etc etc, so i need some help...
preferably before 9pm so i can get some from bunnings
Grega
melbourne.victoria.austra...
Re: 4age engine stand bolts Thu, 01 January 2004 09:16 Go to previous messageGo to next message
alternator bolts worked for me...
FKN16V
NSW, East Coast
Re: 4age engine stand bolts Thu, 01 January 2004 11:21 Go to previous messageGo to next message
Wouldnt you use gearbox bolts. Or is it the type of engine stand that you have that requires different bolts.
Steve
natez
Re: 4age engine stand bolts Fri, 02 January 2004 02:39 Go to previous messageGo to next message
my gearbox and 4ac are still in the car, and won't be out for 2 or so weeks, and i need to prep the 4age to go into the car, but i am sure they wouldn't be long enough anyway,
I'll check the alternator bolts
4a-c
Sutherland Shire
Re: 4age engine stand bolts Fri, 02 January 2004 02:56 Go to previous messageGo to next message
Gearbox bolts are what i used
rob_RA40
c'town, NSW
Re: 4age engine stand bolts Fri, 02 January 2004 04:12 Go to previous messageGo to next message
make a quick squirt down to your local wrecking yard or mechanic, they will have piles of bolts u can rummage thru.
clubagreenie
1st street on the right
Re: 4age engine stand bolts Fri, 02 January 2004 08:53 Go to previous messageGo to next message
Don't worry about /8ths. They will be metric. They should be 10mm, but could be 12. 11mm is an odd size for a bolt (does exist). If you look at your average spanner set it has 6, 8, 10, 11, 12, 13, 14, 16, 17, 19 mm sizes as these aree head sizes for commonly used bolts. Thred size is establised by the holes you drill to tap and by memory 11mm and the others that have the head sizes that are not on the spanner list are not drilled with a straight sized drill, they could be a numbered or lettered drill.
M motors are 12mm (early to 4 maybe 5m) and 10mm after that for example.
If your engine holes pass right through just get something to fit through and use nuts. Couldn't recommend Bunnings bolts though. the only ones I've seen there aren't graded, they are just macine screws. Personally wouldn't trust them.
Sprinta
Re: 4age engine stand bolts Sat, 03 January 2004 04:01 Go to previous messageGo to next message
I went to bunnings and they didnt have the correct thread.
I went to a proper bolt store and got mine..
From memory they are:
M12 bolts (metric)
~100mm long or however long you need them, use washers if they are too long
and the thread pitch was 1.25 im pretty sure..
TE72_Turbo
Re: 4age engine stand bolts Sat, 03 January 2004 06:54 Go to previous message
yep, they are metric 12 x 1.25
you will most likely need to buy from a specialist fittings shop, as the standard (common) thread for a 12mm bolt is 1.5mm, not 1.25 Crying or Very Sad
Phil
Previous Topic:oxygen sensor output analysis
Next Topic:+20 offset on a 16x7 rim for MA61
Current Time: Sun Oct 18 17:57:28 UTC 2026
Total time taken to generate the page: 0.0051531791687012 seconds
