Classifieds » Miscellaneous » 18rg forge pistons new
CelicaRA45
nth ringwood, Victoria
18rg forge pistons new Thu, 01 January 2004 09:30 Go to next message
meant to put this with the throttle linkages 18rg new forge pistons and pins 750
earlyrolla
Re: 18rg forge pistons new Sat, 03 January 2004 15:19 Go to previous messageGo to next message
Are these the same as you advertised previously, the 12:1 comp ones?
Sorry about not getting back to you about them. Unfortunately the comp ratio will be too high for my application Sad
Thanks.
[Updated on: Sat, 03 January 2004 15:20]
CelicaRA45
Re: 18rg forge pistons new Sat, 03 January 2004 22:56 Go to previous messageGo to next message
there 11 to 1 had them checked
levinracer
Re: 18rg forge pistons new Sun, 04 January 2004 03:03 Go to previous messageGo to next message
11:1....awesome they'd make great ashtrays glenn...
just jokes!! Razz
silvercil40
Re: 18rg forge pistons new Fri, 09 January 2004 09:27 Go to previous messageGo to next message
What sort of price you looking at? cos i dont know what i should ask and dont want to insult you.
CelicaRA45
Re: 18rg forge pistons new Fri, 09 January 2004 12:10 Go to previous messageGo to next message
to replace these they would cost 1100 hundred i wont 750 for them
Jonny2TG
Tasmania
Re: 18rg forge pistons new Wed, 04 February 2004 13:23 Go to previous messageGo to next message
I am very interested in these. Can you say what brand they are? Mostly we need to know diameter. Prefer oversize ones as the block will be machined. Can you run these 11:1 pistons with the standard motor and cams, with sidedrafts? Maybe we would need to decrease the compression for my use?
Have they been used before? Come with rings?
CelicaRA45
Re: 18rg forge pistons new Thu, 05 February 2004 05:03 Go to previous message
they are new and are 2tg big bore forge pistons the pin height is higher than the 18 r 1 only have some 2nd hand 18rgu low comp 1 s
Previous Topic:ST162 SX Celica wrecking
Next Topic:CT26 twin entry Turbo
Current Time: Fri Oct 23 12:46:04 UTC 2026
Total time taken to generate the page: 0.0045380592346191 seconds
