Toymods » Tech & Conversions » 4AGE Idle Speed Problem with A/C
HighRolla
4AGE Idle Speed Problem with A/C Thu, 01 January 2004 15:22 Go to next message
I have a problem with the Idle speed dropping when the Air Con is activated causing the car to stall. The car is an AE82 86 model (AFM). Somebody mentioned it may need a new idle speed motor. I don't even know if they have an idle speed motor or some kind of valve (maybe the motor controls the valve??). In the Haynes manual a code 11 trouble code is related to the A/C switch signal. Would this indicate that the A/C unit is not sending the signal to the ECU? I have never used these fault codes to check anything, is it worth trying. Has anyone had a similar problem and got to the bottom of it.
Is it likely it will need a new valve or motor?
I've had the car for almost 3 years and I always turn the A/C off when i come to the lights..suddenly started to annoy me and too cheap to pay to get it fixed. Thanks..any input would be great Smile
HighRolla
Re: 4AGE Idle Speed Problem with A/C Fri, 02 January 2004 00:41 Go to previous messageGo to next message
I tried to attach a photo. Is the check engine connector this spare connector located near the ignition coil. i.e the clear yellowish looking one to the left of the green connector.
Thanks - hope the photo comes through.
Toobs
Re: 4AGE Idle Speed Problem with A/C Fri, 02 January 2004 01:55 Go to previous messageGo to next message
Theres a little vacuum switch which should be over the very back left hand side of the engine bay... if this is buggered or one of the lines to it is blocked your idle up will not work...
I got a new old one from pickies for about $2 Smile
PS nearly all of them are the same along the toyota range... different cars have different brackets but you can use your existing brackets
HighRolla
Re: 4AGE Idle Speed Problem with A/C Fri, 02 January 2004 05:14 Go to previous messageGo to next message
Thanks heaps Toobs. I found what I think you were talking about (sitting in car left hand side, is that it? That's where I found it anyway). Mine had a screw type adjuster on the top. All I had to do was unscrew it a bit to allow a greater vacuum in the pick up tube and the revs went up. I don't know if yours has the same system...but does that sound like the part you were talking about?
I can hear quite a bit of air around now since I opened that valve up a bit , do you think that is normal. Couldn't really find leak in line.
Happy holidays!
FKN16V
NSW, East Coast
Re: 4AGE Idle Speed Problem with A/C Fri, 02 January 2004 11:14 Go to previous message
The screw that needs to be turned has a spring on it, if thats the one you turned then youve found it.
Sometimes they can get dirt and grime into them which will affect the way it works.
Previous Topic:1976 ta23 wiring diagram
Next Topic:why the fuck do i keep breaking these!!!!!!!! {diff shims}
Current Time: Fri Oct 30 20:19:55 UTC 2026
Total time taken to generate the page: 0.0050170421600342 seconds
