Toymods » Tech & Conversions » 1GGT power question, I need more
soaringmik
1GGT power question, I need more Fri, 02 January 2004 00:17 Go to next message
I have very little money, and I want more power out of my 1ggte, I do not want to replace the turbos, as money is a problem. So is there anything I can do to up the power whilst keeping my car reasonably reliable?
[Updated on: Fri, 02 January 2004 00:17]
Chris Davey
sunny coast, qld
Re: 1GGT power question, I need more Fri, 02 January 2004 00:42 Go to previous messageGo to next message
what mods have you got and how many kms on engine?
to start, cold air induction, 3" exhaust and a little more boost, say10psi. If you have done a fair few kms, the turbos may go at 10psi. That is what happened to me anyway. Should get just over 130rwkw with these mods.
Re: 1GGT power question, I need more Fri, 02 January 2004 00:58 Go to previous messageGo to next message
your idea of "very little money" must be different to mine... my idea of very little money means he couldn't afford the $1k for a 3" exhaust.
CAI is definitly a good idea, and very cheap to do yourself, consider a k&n drop in panel for your airbox
and, as mentioned, a little more boost
soaringmik
Re: 1GGT power question, I need more Fri, 02 January 2004 01:03 Go to previous messageGo to next message
No mods, dead standard, 150,000kms. I was thinking about doing something with the air intake as it is quite restrictive, but I hear that the air flow meter kinda gets in the way. I am still learning about this kinda stuff... I had a look at exhausts but it seems I can't get a decent one for less than a couple of grand, I don't have those funds at the moment,
any help would be greatly appreciated
[Updated on: Fri, 02 January 2004 01:09]
Re: 1GGT power question, I need more Fri, 02 January 2004 01:06 Go to previous messageGo to next message
you should be able to get a 2.5" exhaust all the way through, with a 3" dump pipe, for a little over a grand (depending on what sort of cat/muffler you go for)
if you want to do a CAI setup, put a k&n panel filter in, and some piping from outside the engine bay directly into your airbox. Depending on the setup of your airbox, you can either pipe it direct to the stock air box intake, or you can block that up, cut a new hole in the side/bottom of the airbox, and pipe your intake to there
edit: spelling gremlins
[Updated on: Fri, 02 January 2004 01:07]
soaringmik
Re: 1GGT power question, I need more Fri, 02 January 2004 01:09 Go to previous messageGo to next message
does this have any effect on the air flow meter?
Re: 1GGT power question, I need more Fri, 02 January 2004 01:11 Go to previous messageGo to next message
nope - AFM is after the airbox, so it's still detecting the total volume of air coming in.
The only thing that's changing is the temperature of the air coming in (cooler air occupies less space, hence you can get more air through your system without changing anything else)
soaringmik
Re: 1GGT power question, I need more Fri, 02 January 2004 01:21 Go to previous messageGo to next message
Great, for the boost will I need to install some sort of bleed valve?
(probably a stupid question)
Re: 1GGT power question, I need more Fri, 02 January 2004 01:23 Go to previous messageGo to next message
yep, but that's really cheap (like $70, or about $5 if you know how to make one yourself)
if you're going to do this, I recommend you invest in a boost guage (unlike my brother, who just turns the ebc till it feels good, and turns it all the way up when dragging)
soaringmik
Re: 1GGT power question, I need more Fri, 02 January 2004 01:33 Go to previous messageGo to next message
awesome, thanks for the advice
Chris Davey
sunny coast, qld
Re: 1GGT power question, I need more Fri, 02 January 2004 02:45 Go to previous messageGo to next message
yep do those very cheap mods first.
I think you should be able to get a larger exhaust for less than what you said. I got my 3" mandrel bent exhuast for $900 with a 3" cat but no fancy shiny muffler Smile
remember, just because it has some jap brand on it doesn't mean it is any better.
Siktoy ra23
Plumpton/sydney
Re: 1GGT power question, I need more Fri, 02 January 2004 04:03 Go to previous message
If you do the exaust your self it will cost you about $250-300 as for the CAI put an after market ecu on it and get rid of the AFM all together you wont have to put any more boost in to feel the differance
P.S I run an EMS ecu on standard boost and have about 160rwhp
Previous Topic:trouble putting a 1g-gte into a ra23
Next Topic:Gearbox oil change
Current Time: Wed Oct 28 05:20:33 UTC 2026
Total time taken to generate the page: 0.011258840560913 seconds
