Toymods » Tech & Conversions » 3k mods, what can I expect to pay
_555_
SOR, Perth
3k mods, what can I expect to pay Fri, 02 January 2004 02:11 Go to next message
I am thinking of modifying the 3K in my KE30 corolla for better performance.
What can I expect to pay for some decent extractors and a cam regrind?
[Updated on: Fri, 02 January 2004 02:12]
airfireman1
Perth WA
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 03:17 Go to previous messageGo to next message
For a cam regrind expect around $80/90 dollars for a set of extractors expect around $250/280. crow cams do lumpier ones, but they are a lot more expensive than getting yours reground, you can check on crow cams web site for all thier different grinds
I have just rebuilt a 4y Performance Auto Engineering in wangara did all the regrinding for me including the head work I can recomend them. you can get extractors at most exhaust and muffler places.
Dont forget a decent gasket set and while you have the motor disassembled, rings/ balance and some good head work.
_555_
SOR, Perth
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 05:43 Go to previous messageGo to next message
thanks for the info airfireman1, I didn't think the extractors would be so expensive though.
[Updated on: Fri, 02 January 2004 05:44]
SupraBOY
Yeppoon/Rockhampton
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 10:23 Go to previous messageGo to next message
extractors should only be about $160
HyDrA
Adelaide, SA
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 10:42 Go to previous messageGo to next message
What sort of power could be expected after the mods?
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 10:44 Go to previous messageGo to next message
camtech reground cam, abotu $120
stage 3 with stock springs, stage 4 needs new springs.
i have stage 4 (camtech 609)
extractors, look around wreckers, or new between $150-250. i made my own.
_555_
SOR, Perth
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 13:28 Go to previous messageGo to next message
Thanks for the info, I would also like to know how much power could be gained after these mods?
CLG
Perth, Western Australia
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 13:58 Go to previous messageGo to next message
Power output depends on so many factors it would be hard to guess a figure without knowing everything. I recently built a stroked and bored 3K, only to have the owner kill it in under 500KMs through detonation. I was aiming for around 140BHP, but never got the chance to throw it on the dyno for obvious reasons. The build consisted of; clearanced and bored block to suit 4K crank and rods, and Honda pistons, owner's cam of unknown size (a sticking point in thew build, believe me!!!), ported bigport head, 5K head gasket, twin 40mm Webbers and headers, electronic ignition, ...
I still have a brand new inlet manifold to suit twin Webbers if you decide to change the induction too?!?
_555_
SOR, Perth
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 14:58 Go to previous messageGo to next message
CLG: What power figures would a 3K with worked cams, extractors and a full 1.5 or 2 inch exhaust with 2 inch resonator and straight through muffler be capable of?
Also is electronic ignition hard to do on a 3K?
Thanks for the advice BTW.
[Updated on: Fri, 02 January 2004 15:01]
CLG
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 15:47 Go to previous messageGo to next message
Assuming everything else is standard, I'd say around 100BHPish which would be around 70RWHP. Electronic ignition is easy, especially considering I've also got a dizzy I'll sell! Join the Old Corollas Yahoo Group, or ask "oldcorollas" here on Toymods - he'll have a better idea on these matters of power out of K series motors!
_555_
SOR, Perth
Re: 3k mods, what can I expect to pay Fri, 02 January 2004 16:05 Go to previous messageGo to next message
wow, around 100 bhp is not bad, I never thought these engines could produce that sort of power!
Thanks for the advice CLG.
[Updated on: Fri, 02 January 2004 16:06]
Re: 3k mods, what can I expect to pay Sat, 03 January 2004 01:28 Go to previous messageGo to next message
_555_ wrote on Sat, 03 January 2004 01:58
for electronic ignition, just get a Jaycar HEI kit. they work wonders.
as for power, the 1300 class race boys get around 140-150hp from a 1300 3K, ie bored 3-4mm, oversize valves, 300+ deg cams, twin webers, tuned exhaust etc.... but their powerband is usually about 6000-9000rpm, with buggerall below that. the TOSCO manual on my page http://www.materials.unsw.edu.au/~sford describes what is needed to reach this goal, and has cam and porting specs etc.
my current build, which is a 4K, 3K bigport head, 1mmOS pistons, camtech 609 cam, dual valvesprings, much exhaust porting, valve unshrouding and CC shaping, 10.2:1 CR, home made tuned extractors, home made 2" exhaust (2 resonators and reverse flow muffler=quiet), jaycar HEI, weber 34DMS carb etc etc....
it currently has peak torque of about 105Nm@4600rpm, and peak power of about 100-105hp@8000rpm.
basically with good ideas and sensible mods, you might be able to get about 110-120Nm from the 1.3L, or 100-110Nm from 1.2L. to do this, you have to ditch the single carb setup, and either go for the EFI manifolds from 4KE/7KE, or twin weber style manifolds (and EFI TB's would be lovely Wink )
i'm abotu to EFI mine, and am expecting to have a flatter torque curve with around 115-120Nm peak. power doesn't really worry me, but the powerband will be
from 4000-8000+.
it should be relatively easy to get around 100hp from a street motor.. but more than that it gets exponenetially harder and more expensive.
_555_
SOR, Perth
Re: 3k mods, what can I expect to pay Sat, 03 January 2004 01:54 Go to previous message
Cheers for all the advice guys, I never knew that the 3K was capable of anything past 60HP, but hey you learn something new everyday.
Previous Topic:7m camshafts
Next Topic:4AGE stock ECU programmable
Current Time: Sun Nov 1 09:21:39 UTC 2026
Total time taken to generate the page: 0.004831075668335 seconds
